Installing a flat dish
astra19
98cm motorised technomate. 50e to 34.5w
Europe
The coax is newly bought, and lightly coiled but no kinks. I’m getting 0% on the signal, so does that suggest something else is wrong?
Terryl
Custom built PC
Well yes that could indicate a problem with ether, no power from the TV to the dish/LNB, wrong LNB type selected, wrong LNB IF frequency, or something else.
Can you go to your satellite configuration page and post the settings you have listed there??
astra19
Europe
The LNB is set to 9750/10600. The power is on.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Any news? Any success?
astra19
Europe
It's been a real saga. Got the flat dish, had an installer come round and he said the dish was faulty as it was reading 80% signal strength even when still indoors. Sent it back to the manufacturer who said nothing was wrong with it. I've got myself a regular dish in the meantime that I'm attempting to install myself. It was much easier in the analogue days! Swivel it about until you get a picture. Now I'm not sure what to do.
Installing the regular dish will be the same technique with the bleep meter, though your dish face will now be almost vertical. As with the SelfSat, leave the skew until last.
astra19
Europe
Sorry what do you mean by almost vertical? According to dishwater I've got:
Elevation: 26.6°
Azimuth (true): 151.6°
Azimuth (magn.): 150.3°
LNB Skew [?]: -9.5°
astra19
Europe
Actually, ignore me. Your advice was perfect! I made everything neutral and focused on alignment and got a signal instantly. You're a star!
Elevation: 26.6°
LNB Skew [?]: -9.5°
The dish has an Offset - the LNB arm is at an angle of around twenty five degrees with respect to the dish face, so that Offset angle has to be deducted from the calculated Elevation ....... 26.6 - c.25 = nigh on zero. ie Dish face nigh on vertical.
Any unaligned dish with a properly connected and powered up LNB will show a significant - but unwavering - apparent Signal Strength reading. The only fault here is your Installer's competence.
... thought that but didn't like to say
astra19
Europe
No I completely agree. I could tell he didn't know what he was doing. Thankfully they didn't charge me.
astra19
Europe
I'm in the Netherlands, a place called Deschotelshop in Nieuwegein. I didn't have much faith. They said it was impossible to get Astra 2 in my location but I knew that wasn't true. Now I have hundreds of channels coming in crystal clear. Thanks again for you help! Kept me sane.
a33
XSAT410
Rebox RE-9000
The Netherlands
With my XSAT 410 receivers (I have several), that depended on the firmware loaded to it, IIRC.
Some firmware showed only signal strength, when signal quality was also present;
some firmware showed signal strength, with 'just' an LNB attached.
The latter confused me, till I discovered this difference, compared to the firmwares I used before.
So I wouldn't put this statement with any absoluteness.....
Greetz,
A33
astra19
Europe
That would make sense actually. My box doesn’t show signal strength without signal quality.
