Listen Up Octagon SX88+
mr.smith
Gibertini 150 cm + actuator 18" + Pace msp 995; Fibo Stop 90 cm + diseqc motor ; Octagon SX88 V2 4K 5G wi fi ; Octagon SF4008 Dual ; Dr. HD 1000 Combo
Croatia
A question about signicant differences between my SX88 and the SX88+ receivers in respect of the firmware update procedures as follows:
- both receivers are connected to my router by Cat 5E cables (i.e. I do NOT use WiFi connections), and both can load up and run files from the various streaming sites shown in the menus
- with the SX88+, when Octagon releases a new firmware update, the receiver automatically displays a message to inform me of that as soon as I switch it on and it has booted up. I can then tell it to download and install the update - and that works correctly.
- OTOH, with the earlier SX88, when I switch it on there is no message displayed about available firmware updates and so I only find about those from what you post in this thread. I then have to manually download the update from the Mediafire website link and load it via the USB flashdrive method because if I try to download it directly using the receiver menus , it displays a message that appears to say that it does not know from where any updates can be downloaded and just shows a list of " *** " instead of the URL of the download site files in question!
Therefore please can someone explain why there is this difference, and specifically why the SX88 cannot find the firmware update download site?
Thanks in advance
Thanks in advance
My old SX88 always tells me there is an available firmware update. Mine is hardwired.. Not used the USB option for years...
So, that implies that "something" is missing from the setup menus, and that would seem to be the URL for the update files - therefore it would be very helpful if you or someone else could post that so that I could try to enter it (with the R/C :rolleyes: ) :)
Try a factory reset?
mr.smith
Croatia
Try using the ftp tool to get into one receiver and in the other, so see where the difference is. It is possible in txt format, so you can edit.
mikeisyou
Feed Hunter
England
Old post but I try: how did you manage the fransat together with the sx88+? Completely new on this decoder so I need some help, thanks
Likewise I can't post my config here but I can point you in the right direction. Via ***** through the alternative software patch. This solution does not work with RMC Sport, I'd be interested to know why you would need this card as most of the channels would be available FTA.
Alejandro_V
Channel Master 120 with Inverto PLL LNB
Oslo, Norway
The thing is that they are FTA as multistreams and the C/N lock for those is too high for the quality of the reception here. I am way out of the footprint, that's why I would like to have my card read by the octagon even if I will not get the paid channels...Thanks for your help!
http://www.octagon-germany.eu/
Firmware (Software) Update V10520 11-05-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. New F-TV Function added.
2. Some minor issues fixed.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10520.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10520.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10520'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
mikeisyou
Feed Hunter
England
I'm having some problems reveiving the Multistream of Mediaset Italia Due on Eutelsat 5 West. Is anyone else having this problem?
Lots of changes try deleting channels that do no clear then rescan all including multi-stream.
I just re-scanned & some channels have returned some have gone.
Sport Italia is back on 12606 V 35500 Multi-Stream so is Mediaset Italia Due..
SnelleJef
Triax 88 Inverto Black Ultra Lnb And The VU+ Zero 4K
Belgium
they changed there parameters to 12606.00MHz, pol.V (DVB-S2 SR:35500 FEC:2/3 SID:7066 PID:440/441 ,442 and some channels are gone
Many changes going on ...can't keep up!
Will leave it a few hours to settle down
mikeisyou
Feed Hunter
England
Fantastic, I've gained Mediaset Italia Due and lost Rete 4 HD, Canale 5 HD, Italia 1 HD and Mediaset 20:-rofl2 . This is like whackamole
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Anyone tell me why the option to factory default will not do anything at all ? Also does disqec 1.2 fully work ?
DiSEqC 1.2 works OK but if you use more than one receiver on the same motorised dish it is best to use DiSEqC 1.3 USALS.
