Eshail 1 sat in south west (bath)
The united fan
Somerset , Uk
80cm Sky Dish
Somerset
I'm wondering if it's possible to recieve the channels on this satellite as I want to buy a bein card + box for the football. I'm also aware that if it will be possible I'll need a big dish. Has anyone had any success within this area?
The sensible answer is no.
Searching across the forum there is one report from Swansea which isnt too far from you - no reception on a 2.4m dish. So unless you have the budget & land to go MUCH bigger than that - forget it.
I am in Bristol (ish). Not a sniff on 1.8m from this satellite. Ironically, further north there is a success story from @nelson_b who received a few transponders on his 2.4m,so I think we are in a "null" here.
nelson_b
Contributor
Will have a look again today and see what i can receive .... as i recall i can see some signal from the Bein transponders on the 2.4 ..... but well below lock.
I was sure you received some DVB-S transponders at relative low lock (below 5dB )
nelson_b
Contributor
Your memory is better than mine C.J. ..... Just had a quick look now and locked a transponder at 5.6 d.b. ... need to go out for a while now but will return to this satellite in more detail later. Blue nile.jpg
Cheers.
nelson_b
Contributor
No more locks .. from Es,hail 1 or 2 ....... with 2.4 Channels master offset
ESH2 is a different kettle of fish. It's much stronger than 1 - in the south at least. I get a couple of transponders from that.
