Changing blind scan settings on Edision OsMio 4K plus
Paolo71
Gibertini 100cm, STAB HH120, Inverto BU 0.2dB, Laminas 120, Moteck SG2100A, Inverto Premium 0.2dB.
TBS 5925, Edision OsMio 4K plus, AZbox Premium HD+, pc AMD FX8350 ram 32Gb. IQMonitor Pro, EBS Pro, Crazyscan, DvbDream, VLC and PotPlayer.
Monterotondo (Rome), Italy
Hi all, I'm looking for changing settings for blind scan, for an advanced one, I would like to find a way to change blind scan steps, knowing that nominal blind scan interval, on Openatv and other images, is about 4 or 5 mhz. I want to change this interval down to 1 or 2 mhz just to find and separate close transponders. Any help please ? I have got an Edision OsMio 4K plus with Openatv, Satdreamgr and OpenPLi images. Thanks a lot.
Manikm909
Small'ish Dish Man
Kent, UK
stephan94
Bavaria
there is no problem for the blindscan of the MIO4K with the Openvision image (openPLI either) it finds two frequencies with 1mhz between the two
Manikm909
Small'ish Dish Man
Kent, UK
great ! mine arrives today!
Manikm909
Small'ish Dish Man
Kent, UK
the blind scan setting in E2 actually allows you to specify the scan steps before you press go\scan !!!! jeez
Paolo71
In my Edision OsMio 4K plus I cannot select the scan steps in mhz, but only the symbol rate interval (on OpenAtv, on Satdreamgr, on OpenPli). Maybe is there any other image where I can find the blind scan step selection (in mhz) ? Thanks a lot.
Paolo71
For sure I am used to find channels through blind scan with my TBS 5925 and Ebs Pro as well. Then when I bought the Edision something changed some points of view about blind scans and their complete scans. With EBs Pro I can choose till 0.25Mhz blind scan step ! That's a deep scan, but longer.... Anyway Edision and Open images have very good capabilities ! I am waiting for new developments.
Manikm909
Small'ish Dish Man
Kent, UK
there appears to be NO blindscan option in OPENPLI
stephan94
Bavaria
Manikm909
Small'ish Dish Man
Kent, UK
Thanks . What version of PLI. I couldn't find option on latest
MCelliotG
Thessaloniki, Greece
You need to download blindscan from the plugins feed, it doesn't come pre-installed.
Manikm909
Small'ish Dish Man
Kent, UK
