Offtensive
- Apr 14, 2021
- Sky Q, GigaBlue UE 4K, Zone 1 28.2e, Zone 1 30W. Kathrein 1m 5W - 23E
- Midlands
Hi all,
I currently have a Zone 1 minidish that I use for Sky Q along with their hybrid lnb and I am looking to add on a second or possibly third lnb. I'm quite new to this so have a few questions.
With the Zone 1 dish, realistically what would be the max width/span that I would be able to cover? I currently have a spare Inverto Ultra Black lnb and an old Sky Quad LNB. I've seen the alps lnbs, I'm happy to buy them if that means I can squeeze in more.
I'm quite interested in getting 19.2e, if I could say squeeze 13e on to that dish too that would be great.
In terms of multi bracket options, I've been recommended the Gibertini Multi 4 (below). As my Hybrid Lnb is 37mm, if I was to tape around it, would that be secure?
Robust Multi 4 Way LNB HOLDER - Gibertini - MF-2140 / beware of copies
A few people have recommended to me just using tape/cable ties to add the second lnb. And if my Sky Q lnb is not secure in a 40mm holder, I'm quite open to that. What I am curious is, if it is possible to tape 2 lnbs to one side, so get 19.2e and 13e with 28.2e in the centre? I'd be interested to know if that could work on either the Zone 1 or Zone 2 dish.
Alternatively I have looked at the lnb holders like the one below. As I understand with them, they just go around the lnb and don't attach to the arm. So if I need to attach tape my Q lnb to get it to 40mm, I'm happy to use a holder like the below if that means the Q LNB is more secure as it would be attached directly to the boom arm.
Multi-LNB Holder for All Satellite Dishes Holds up to 3 LNBs With 40mm Diameter | eBay
In terms of upgrading the dish, due to the high risk of me having to sleep in the shed, I'm limited to an elliptical dish. Upgrading to a Zone 2 dish is a possibility, ideally I would try on the Zone 1 first and then upgrade if need be.
Thanks in advance
Thanks in advance
