How accurate is "line-of-sight" on DishPointer.com?
samcruise
None yet
Shropshire
Is the green line-of-sight on Dishpointer.com pretty much spot on in terms of the direction it points in for the various satellites, or just a rough guide?
I'm trying to avoid trees...
I would treat it as a rough guide.
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
I have checked it out and for me dishpointer is a few degrees west of where my dish actually needs to be for each sat but it is ok for a guide.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
On this subject I'm trying to use the dish pointer website using various locations and satellites but it always seems to come up with an obstacle in the distance of 49.9 m and 22.2 m height even when I put the pointer (dish) in the middle of a field?
Edit I just found I can move the small marker.
Terryl
Custom built PC
Yup, moving the marker to were the dish is mounted helps quite a bit, entering your exact address then zooming in as close as you can to were the dish will be mounted helps, moving the little marker is getting it as close as it can be.
I found that it's about +- .25 degrees from true dead on, on most satellites I have run across.
Terryl
Custom built PC
When it comes to trees, the higher you can get the dish the better.
