Intelsat 20 68.5 East
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Finally, it appears that the transfer of the channels have started at C band.
According to Lyngsat the 4064H 19850 7/8 shifted satellite.
Before I had signal strength of 10.2 dB on Intelsat 10, Intelsat 20 I have 11.3dB.
Slightly stronger , wondering if I get into Indian 8qpsk channels.
Prodelin 2.4m in South Sweden
Baram
Darlowo
Poland,/ Darlowo
Can u get any c band Indian and Pakistani channels ?
Lasseparabol
3 m Prodelin
Echostar AD-3000IP
Dr.HD F15
Sweden south part
I can receive the Following txp with several Indian channels, strength in parentheses.
68 East: (only listed txp with many channels)
4103V (5.9)
3864H (7.0)
4013H (8.1)
4090H (9.0)
then there are several more Indian txp but I would need a 3m satellite dish to get into them.
Think you can get in some txp on a 1.8m, but if you want receive many, it is probably a 3m only option.
Also a large number of Indian channels on 66 east Intelsat 17, strength is about the same but the slope of the horizon is slightly better!
Baram
Darlowo
Poland,/ Darlowo
ok thnx :) and i want TenSports Channels / 3712 H 14454-3/4 QPSK this one i want ? and Satbeams Shows 250 cm is fine for it ? what do u think about that can u chek this one plz with ur 240 cm dish ?
He has already given you that answer - 3712H isnt available on his 2.4m, and a 3m dish is likely to be needed in Sweden and therefore where you are. Plus you would need a suitable subscription as they are encrypted..
Might be a bigger dish is needed as well as they are DVB-S2 & 8PSK
Kveys
Southern Finland
TEN Sports 003.JPGTen Sports 3712H (Vpid 52) Pakistan version FTA atm. Maybe because of Pak-Ind cricket..?
Edit: scrambled again
j-f-k
1,6m prime focus aluminium dish + 0,3dB Invacom KU-Band LNB, 1,8m prime focus mesh dish + 25K C-Band LNB
Lithuania
4103V (5.9)
3864H (7.0)
4013H (8.1)
4090H (9.0)
I was trying to catch NHK channels on IS-20 3840 H with my 1,8m C-Band dish, but no luck.. What is the real strength of this signal?
j-f-k
Lithuania
Yes, I think so. Can somebody confirm in Europe/UK that it is possible to receive IS-20 3840 H, and if so - what is the dish size? And experience about the reception during the year - how the signal changes.
mar-val
Slovakia,Zilina
You should get it easy ,I think. Friendly modulation and FEC: S2QPSK 2/3 , lock around 3db.
Reception with 2,2m.
j-f-k
Lithuania
Thanks, interesting info. Lithuania is above Poland, so I think I should use at least 2,5m dish. Now my question is - where can I buy a good 3 m parabolic dish in Europe? This size is a problem in Lithuania.. :)
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
Buying a bigger dish ain`t any problem even in Europe as there are still companies that can supply anything you want..... But the question is how much you want to spend.
For your information there`s a price list of Prodelin dishes made by General Dynamics attached in this reply. It is more or less similar to the final price you`ll end up paying when the dish is ordered in Europe.
For example, my Prodelin 1375-990 3.7m cost $3742.55 - (3.7m with polarmount, C band feedhorn + OMT: $3195.15, Delivery from Germany to Slovakia: $547.40).
Otherwise, if you`re lucky enough, there are time by time used or brand new dishes available for a quarter of the new Prodelin dish. In my case, I`ve been waiting for this opportunity for last 11 years... But now I`m a happy owner of the new Patriot 3.8m & 5m antennas even I already have 2x 3m mesh, 2x offset Prodelin 2.4m and 5x offset Prodelin 1.8m.
Because more and more transponders use DVB-S2 8PSK modulation, 3m+ has become simply basic requirement for DXing in C band.
  • General Dynamics price list.pdf
j-f-k
Lithuania
Yes, I expected these prices. I envy you now :)
Some time ago I found this site/manufacturer (RF HAMDESIGN) of mesh dish: 3 Meter MESH DISH KIT (F/D=0.4 - 0.45)
Are they reliable and what about performance?
