thanks smoggy,im just woried about connecting the dreambox,as somone said that they will cut me off as i use bt vision also,so it will be fine to do this??
thanks
stevo
I`ve used my dreambox on BT internet before and had no problems with it but I have never used a dreambox and bt vision together though
As far as I`m aware the bt vision box only hooks upto the internet for premium channels/ondemand not sent over the freeview dtv muxes, this "should" have no effect on any other networked device
I think I can safely say you shouldnt have any bother using a bt vision box and a dreambox both on the same router, if you are still worried, get a second router of the cable broadband flavour and hook it upto a spare ethernet port on your bt hub then plug your dreambox into this second router, this way, (if I am working this out correctly) the bt hub will only see the new router and wont see the dreambox
As said though, they shouldnt cut you off, unless there is something in the bt vision terms that stop you from using a dreambox on your broadband line, if they did cut you off you could "have them" in some way or other for cutting you off, causing them to be in breach of any contract you both may or may not have entered into
