How to check what modulation a feed is in ?
Archived-1
Persona non grata
uk
I am not sure if my wordings are correct but how can i tell if a feed is in dvb-s dvb-s2 8psk etc etc using a stb, my sat card tells me using crazy scan but i am unsure how to ceck using a stb.
i use various stb is it something in the pid/sid etc please ?
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
I don't have HD stb to tell you how to check it exactly, but I guess it should be appears as a banner on the bottom of your tv screen. Correct me if I'm wrong.
Archived-1
Persona non grata
uk
i don't have any banners mephisto but having a closer look it could be something to do with MPEG/ACC etc ? that relates to my Q ?.
BlindFaith
TBS 5925
If your STB doesn't provide the modulation parameters there is no way to find out.
The NIT contains a Satellite Delivery System descriptor. But the provider is responsible for correct parameters and feeds mostly use some default values. And again, your STB won't show the descriptor (internally it will be used for NIT search).
<TransportStreamID HValue="0x07FD" Name="10773.25 MHz">
<OriginalNetworkID HValue="0x0002"/>
<Descriptor HValue="0x43" Name="Satellite Delivery System">
<DescriptorLength Value="11"/>
<Frequency FValue="10773.25" Unit="MHz"/>
<OrbitalPosition FValue="28.2" Unit="°"/>
<WestEastFlag Value="1" Name="East"/>
<Polarisation Value="0" Name="Linear Horizontal"/>
<ModulationSystem Value="0" Name="DVB-S"/>
<Modulation Value="1" Name="QPSK"/>
<Symbolrate Value="22000"/>
<FECInner Value="4" Name="5/6"/>
</Descriptor>
</TransportStreamID>
Some receivers tell you in an info table. The Duo has a handy banner with all the transmission parameters on it.
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
Archived-1
Persona non grata
uk
For instance how could i check with the skybox f3 A/S ?, I know pressing info gives you details but how could i find out what the feed is transmitted in for reporting feeds.
heres the info for BBC 1HDView attachment 56977
Not as simple as that. The Duo has not got a blind-scan tuner so those values were entered either manually or from satellites.xml. And what you are seeing is just an extraction from lamedb. But if those values have come from a blind-scan capable tuner and the receiver is incapable of correctly returning the tuner status those values will be wrong even though the receiver plays the service.
Oh and the Duo is still the biggest POS Ive ever used.
pontiend
Contibruter
south yorkshire
I found that out a while back with my Alien2.The information in menu told me that a transponder was DVB-S QPSK.When in fact it was DVB-S2 8PSK.I had scanned it as DVB-S QPSK,Thats from memory. Hope that it makes sense.:)
If anyone had known it was for hooking up to a CRT portable via an RF modulator I doubt they would have recommended it.
:-lol
