21.6E 4.2.2 feed ?
Archived-1
Persona non grata
uk
Hi can anyone open this feed please its been active for a good while now I have it locked at 11588 H 5000 thanks for any information in advance.
Just a 4:2:2 testcard on that.
Archived-1
Persona non grata
uk
Thank you Huevos this is all I get atm I need to get my pci card up and running.
Archived-1
Persona non grata
uk
It must be active atm I am getting this,
That grab is just streamed from the STB to the laptop.
Still getting the testcard here. Maybe it was just active for a couple of minutes.
Archived-1
Persona non grata
uk
I don't have a box to do that huevos, I do have a pci card that will open 4.2.2 feeds but I need to learn how to use it.
Assuming you have Crazyscan for your pci card Martin, after a successful scan of the feed, set Crazyscan to point to your TSReader.exe file (if you haven't already done so - I know you have TSReader). This will invoke VLC, which will open your 4:2:2 feed.
remlap
Wales
You can invoke VLC directly from CrazyScan now as well.
Yes, I know remlap, just thought having TSReader as the intermediary he would find it useful for its many functions (pid checks, charts etc.)
remlap
Wales
I've tend to stick with older versions of CrazyScan before now, always features being added I've missed out :)
Archived-1
Persona non grata
uk
Thank you, the last time I had a play with it I am sure I had a problem with drivers for the skystar 2 pci card. I will set it back up in the new year and try and get it up and running.
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
hey martin, assuming that your using the skybox f3,
if you come across 422 feeds like this one but have no way of viewing them,
you could always pop in a usb in the back of your box,
make a recording of the 422 feed and simply play it on your pc using vlc player,
works fine with my skybox f5s so dont see why it wouldnt work with the skybox f3
Archived-1
Persona non grata
uk
Thanks saj, I used to use a dream box and stream it to laptop via a web interface from memory, like you say I can not see any reason why it would not work on the f3 I will give it a go thanks m8.
I noticed a post on satelliweb today that the tp above was active with Moroccan football.
saj1985
Lost...
yea just try it out and see how it goes mate...
if you've got a usb laying around,
heres a 422 feed on 23.5E right now if you want to give it a go,
23.5E 11500 V 6110 DVB-S2 MPEG2
channel ID is RDS DUBLIN and by the way its rugby lol
He is not saying stream it. Put a USB pen drive into your STB and record the channel to the pen drive. Then plug the pen drive into a PC and replay the recording with VLC.
Archived-1
Persona non grata
uk
Thanks lads I did know what saj was saying huevos thank you, I was just pointing out how I used to do it shame the skybox does not have a web interface,
Ok I have just recorded a 4.2.2 stream to usb stick and trying to play it in vlc I have sound put no video codex needed ? I am running windows 8.1 thanks for any ideas just going to drop the wife at work and I will have a play thanks again lads.
"Do I not like that"!
Archived-1
Persona non grata
uk
Thanks ive got it sorted it was codex, I have just installed this pack and all is well :).
filehippo.com/download_klite_codec_pack/
saj1985
Lost...
