help need with quality on turksatm
jemey123
Motor Technomate TM-3000
london
Hi, im trying to get turkish channels but i only have a quality of 5%. How do i fix this? Please respond as soon as possible
Mickha
North West
Which satellite and what is the size of your dish?
Are you trying to get the East beam channels on 42E?
satelliteman
Hi, we need more info I'm afraid in order to help.
jemey123
london
im using technomate tm-3000
Which channels do you want to get? You will only get west beam stuff here in the UK
Please answer the questions we ask properly - they are important.
We have to work through methodically as none of us are mind readers and you may be after the impossible
Now which channels do you wish to watch?
No we cannot answer quicker - this is a volunteer forum - none of us are paid and you have had a string of answers in a few minutes. Let me remind you its late on Sunday night, so few people are around.
jemey123
london
Oh sorry, i wish to watch channels such as Euro D, Euro Star, Atv Avrupa, Show TV, TRT etc
jemey123
london
I just need 42E
And I need to sleep.
Theres nothing that cant wait until the morning.
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
you need to give as much info as possible.. you are using a motorised dish, are you using diseqc 1.2 or usals to locate the satellites? what size dish do you have? are you using a universal lnb? tell us as much info as you can so we can try and eliminate what the issue could be... as stated you will only get the west beam channels in london with a normal sized dish but with a good quality 80cm you should get over 200 tv channels and many radio aswell all free-to-air. what other satellites can you receive? are you getting 39east or 45east?
so we have established these points going off your forum info
1. tm3000 sd mpeg2 stb
2. location is london
3. motorised dish
jemey123
london
you need to give as much info as possible.. are you using a fixed or motorised dish?, if motorised are you using diseqc 1.2 or usals to locate the satellites? what size dish do you have? are you using a universal lnb? tell us as much info as you can so we can try and eliminate what the issue could be... as stated you will only get the west beam channels in london with a normal sized dish but with a good quality 80cm you should get over 200 tv channels and many radio aswell all free-to-air
I am using a motorised dish. And i am trying diseqc 1.2 and usals but nothing works. my dish size should be big because before i had loads of channels and radios. I am using a universal lnb. I think my dish is 8ocm.
jemey123
london
3. motorised dish
I just need the quality to increase and then im fine
jemey123
london
3. motorised dish
i am getting 42East
jemey123
london
its says:
Motorised Setup
Satellite: Turksat 2A-3A (42E)
Transponder: [1] 11962/V/3333/3/4
Diseqc Motor: Diseqc 1.2
Move: Stop
Move Fine: Stop
Motor Control: Press OK
Command Type: Go To Position
Strength: ---------------- 85%
Quality: -- 5%
jemey123
london
3. motorised dish
its says:
Motorised Setup
Move: Stop
Move Fine: Stop
Quality: -- 5%
jemey123
london
