Advice Needed Channels from which satellites are available in Ireland
net4hack
Triax 88 cm Dish + 4 Octogon LNBs, 2 Diseqc switches, 42" Samsung Plasma
Intel Dual Core + 2GB Ram
Dublin
Hi Guys,
I am planning to install a satellite dish system with 1.1 mtr motorised dish. I would like to know channels from which satellites would be available to me.
Would all the channels listed here are available (73°E-0°E) - http://www.lyngsat.com/tracker/europe.html
Also any Atlantic (0°W-61°W) or Asian (160°W-73°E)?
Appreciate any help ...
BlindFaith
TBS 5925
a) Only signals from visible satellites can be received. For your location: between 75°W and 65°E
b) The satellite antenna has to point in your direction -> footprints from satellites within limits a) can found on satellite sites like Lyngsat, Flysat, KingOfSat
Hi Guys,
Antenna 1.1 m is able to receive more channels, but,a great but,now depends on how you adjust the antenna.And even if the antenna is well tuned , it is impossible to receive all channels from 73 E to 73 W,because many satellite signals have different spots.You have big chances that you get signal from the European spots,and in many cases even the Middle East or the Mediterranean spot.Now depends on what area you are.
