Help Required Pixalation in Anevia 220S streamer
sibymathew
I am using Anevia 220S streamers and Minerva middle ware and Amino setop boxes.
Saudi Arabia, Riyadh
Hi All,
I am getting pixalation (disturbance) in the channels through Anevia 22os streamer.When i am removing the input coaxial cable from the streamer and connecting back channels are working normally.This is happening frequently..any one face the same issue?...please help me ..
I am using Anevia 220S streamer and miverva server. setup box is Amino.
Regards,
Siby
satelliteman
Is this query regarding pay tv / ip network streaming on a commercial level. If so, we cannot discuss here.
sibymathew
This is an IP network streaming setup inside a research center.
Have you upgraded the firmware to the latest available? If its an early release on it there may be problems
sibymathew
Yes the firmware is the updated one..
Try rebooting the switches it passes through (ask your IT guys before pulling any plugs out though! :D)
Or try a different ethernet point - Ive seen odd problems down the years caused by bad terminations or failing network cables.
sibymathew
Ok that we will do..:)..But is there anything related with static electric???..Because most of the time it happen at the time of sand storms...
Could well be! Sand storms can certainly get electrically charged.
Not a problem here in the UK so we would never have come up with that idea - more likely problems here is snow on the satellite dish arm:-rofl2
Unfortunately if it is sand storm induced static then you will probably have to put up with it.
Could static not be discharged via some earth point?
Possibly, but Im assuming the static discharges across the sandstorm are interfering with the incoming signal itself, much like heavy rain can do to satellite signals here in the UK.
sibymathew
We provided good earthing for all the IPTV devices then also we are facing the issue..after unplugging and re plugging we are getting quality pictures...:-ohcrap
Are you saying it's all working properly now?
If so, well done!
But OP is saying that pixelation disappears after unplugging and replugging the coax. So I assume this process discharges the static...?
Where are you getting the original signals from in the first place - the internet or an external dish / aerial?
sibymathew
It is from dish farm..We have 8 dishes and from dishes it is coming to 2 multi switches ,from there streamers..
You could try earthing the dishes if they havent already been done, and double check the multiswitches are well earthed..
sibymathew
Thanks all ..we will check all the things and update you all...:)
