Amos 3 4.0w European Beam
I can usually get most of the Amos 3 H channels OK where I am on a Gibby 1.25m - I check 11389H first, and work my way down from there. One that I can't get though is 11181H.
Archived-1
Persona non grata
uk
There was a few H TPs that would not lock Llew, 11181 was one of them, do you get the V TPs ok they come in stronger than the H at my location.
Yes Martin, never a problem with the Verts -
Archived-1
Persona non grata
uk
I was doing a few tests here tonight Llew, I was locking all the V TPs, but struggled with the H.
I could only lock 11303 and 11389 at the time of testing, conditions was overcast.
You're doing well though Martin, it can be a tricky one given the footprint, and considering your location.
Archived-1
Persona non grata
uk
Thank you Llew, I will be doing further tests here, at various times and conditions.
digi247
NW
see sig
11389 locks for me here but not solid enough for a stable picture, Been pretty poor with the Rain all day and its not great at the moment maybe worth a try when we see clearer skys
Archived-1
Persona non grata
uk
Its locking fine for me today digi247, clear skies :) , I will go through all the H TPs again when I get time:).
Locking OK here with heavy clouds around - but dry.
Blind scan - verticals are generally a lot stronger than horizontals:
On my 1.1m dish I get 22 FTA TV Services from 4W, from the following 3 TPs only:
10759 H 30000
10722 V 30000
10806 V 30000
All Manual/Network as Blind Scan brings in 5W of course.
All manual as Blind Scan brings in 5W of course.
Er....forgot about that. In which case, some of transponders in my blind scan screenshot ARE probably from 5W.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
No chance down here for Amos 3 at least with a 1.5 Dish. Amos 2 no problem.
digi247
NW
see sig
Yep finally got a Lock when i got back today never tried this morning but now is AOK but after fine tuning these i find that i start to lose 10722 H 27500 the Spacecom Mux, I cant find a happy in between medium for the 2
Archived-1
Persona non grata
uk
I have had the same with two different beams in the past digi, a few clicks one way locks one beam and vice versa.
