Any method to find out, which ones are original and which ones fake ?
Unopened and really compare the electronics, there is only shop at trusted.
Those who have one for years and have small antennas can easily compare the levels and quality of these LNB X.
Consultare a friend antenna installer and ask at the store where you buy if they are offering cheaper units.
Looking at the photo, differences, apart from the black cover, the protective connector "F" is now white.
2 more things.
It is the
twin box model used for single and lack of direction inverto
.tv (TM)
Sin abrir y comparar realmente la electronica, solo queda comprar en tiendas de confianza.
Los que tenemos uno desde hace años y tenemos antenas pequeñas podremos comparar facilmente los niveles y calidad de estos LNB X.
Consultare con un amigo instalador de antenas y que pregunte en los almacenes donde compra si estan ofreciendo unidades baratas.
Mirando la foto, diferencias, aparte de la tapa negra, el protector del conector "F" ahora es blanco.
2 cosas mas.
Es la caja del
modelo twin usada para el single y falta de la direccion inverto
.tv (TM)
For the price it is easier to know that it is a copy.
Por el precio es mas facil de saber que es una copia.
Normal lnb = rs.250 ==> 3.51€uros
Inverto lnb = rs. 1900 ==> 26.70€uros (the original. ??)
In Spain 17 €uros 2 years ago/En España 17€uros hace 2 años (Inverto single IBU 0'2dB ).
