Intelsat 17 66.0°E
aceb
Prof Tuner 7301 /
Sussex
New parameters for the MIR stations, now on 12661H 2900 7/8 QPSK. Mir Service 2 and MIR+3.
MIR Service 2_0660 12661_H_2900_20140427_162823.jpg MIR+3_0660 12661_H_2900_20140427_162817.jpg
pride21
Sandown Isle of Wight
nice one aceb tried this bird many times all I get is some movement on some transponders plus there is a block of flats in the distance.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
61% Quality here - 66E and 68.5E are the last 2 satellite I can receive on the eastern arc :)
Archived-1
Persona non grata
uk
Hi, I am getting a few data TP from this position and 12595 H 6666 and a few radio @ 12602 H 2000.
This TP is very temperamental for me and it's 50/50 whether I get it or not due to low elevation. This is only on 90cm Fibo, though.
I'll be lucky to get to 57E with the 1.8m :(
Archived-1
Persona non grata
uk
:(, your dish size is letting you down pal, your elevation is nearly the same as mine.
Yep, I'd say the eastern limit/elevations for us is about the the same as we are both on the same "curve". Even with 57E, I'll be happy.. there's lots to see anyway :) But even more beyond that, destined for the Indian sub-continent.
I maaay put either a 1.2m CM or 1.2m Fibo up on the wall to get those far eastern sats but need to do a site survey first.
blademedia
Sky
Hello SPEDA coming in today 11613/1500/V also a feed active Ericsson Service 11192/2894/V
adonis1
8 radios on 11092 V 2000 (13.6 db)
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
blademedia
Sky
Clear sky here tonight, solid lock on SPEDA
Is anyone in the UK receiving 11580H 2400 1/2 DVB-S? According to Flysat MATCH! is FTA on this transponder :)
Techinally should be doable, given that it's in DVB-S with a huge FEC of 1/2. So even a low signal should yield results.
I tried with a zone 2 but no lock, it's probably behind a a tree. Will try again up on the roof when the weather improves.
11580H 2400 FEC is now 2/3.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
It's FTA . Here in Bulgaria now(it's raining):
.. Checked this morning with a 1.2 CM from a very frozen over North Nottinghamshire UK
