New Inverto KaKu lnb
Trust
Nijmegen Netherlands
Found at a German board , member Delfi got his hand on a Inverto Ka /Ku combi lnb
Switchable between 10,7-12,75 GHz, and 21,2-22,2 GHz.
This lnb already listed in a Inverto cataloque from 2013 with no specs .
Delfi tested it against a XMW PLL at 16º E , found the same TP's with 1 dB more power .
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Very interesting indeed...
On my shopping list if it ever becomes available ..
curious though ..
Polarity wise ...
obviously it can switch between the 2 bands ...
How is this done since 22khz is needed for band switching in Ku ..
Which leaves V/H available ...but if this is used for polarity switching in Ku ..then how is the switch from Ku to Ka accomplished ?
Or is it simgle polrity only ?
H or V depending on physical orientation ..
ie H Ka and H Ku ...22khz upper Ku
or rotated through 90 degrees
V Ka and V Ku 22khz upper Ku
more info please...
I guess the Ka/Ku output will output Ku by default, and can be switched to Ka by a DiSEqC 1.0 command just like ordinary monoblocks?
And all existing sats with 21.4...22.0 GHz use linear, thus Ka and Ku will be linear.
Edit: corrected!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
And all existing sats with 21.4...22.0 GHz use circular, thus Ka will be circular, Ku linear.
That has me confused buddy ...
Ka D uses linear not circular ??
..and of course ..a diseqc 1.0 command might be confusing for switched setups with motor control ..
This wouldn't be an issue of course on a static dish..
Just curious how it works for real tho'
rgds
VS
Sorry I was confused, indeed Ka D is always linear!
Archived-1
Persona non grata
uk
If the link ive posted is about the same LNB, maybe the continuous streams or something to do with this ? just a thought ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
You may well be right Martin ...but damned if I can navigate to a pdf for this lnb ..
Just keep finding the same link you posted ..
If it's on invertos website ..it's well hidden.
rgds
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Trust
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Still doesnt say much about the IDLK-SINL20-KAKUO-OPP
The info is refering to the Twin Ka circular used at 9E
So ...we are no wiser..
Trust
The picture of the KaKu in that 2013 cataloque is unpunctually , thats a sign .
The single one in the middle is also not available since the project for Egypt did not start .
Could it be one of those 'smart' Ku downlink/Ka uplink LNBs ?
www.eutelsat.com/files/contributed/news/media.../Fiche_Smart_LNB.pdf
Archived-1
Persona non grata
uk
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cant see it being a Ka uplink lnb like an Hughes ODU ...
But I guess it could monitor certain uplink frequencies ...like those it already found on 16E.
But why would anyone make one Ka D capable unless ..this was indeed the future of spectrum use in satellite..
rgds
VS
Trust
CH did you not read : Delfi tested it against a XMW PLL at 16º E , found the same TP's with 1 dB more power .
That was on Ka band .
He posted some more today , translated for you :
with DiSEqC 1.0 A is Ku, with B Ka.
At the Ka only port extremly good signal , found this morning 11 TP's , one more as with the PLL lnb .
Nine of them between > 10 and 15 dB . With the PLL lnb only about 5 / 6 TP's > 10dB
At the other port , switchable Ka / Ku , some losses at KA ( about 0.7 dB ) but still equal to the PLL lnb .
The KU part seems to be a little less than the BU ( 0.5 / 1.0 dB ) but maybe the cloudy wetter has something to do with that .
Tested at TBS 5925 card
Also wrote : there have been already 6500 pcs made .
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ..any idea when they will be available to mere mortals such as myself ??
..and roughly the cost ?
Delfi is obviously 'in the loop' at inverto ..
perhaps he could find out ?
Yep, I'd be interested in one
