36E (Eutelsat 36B)
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I've scanned this bird tonight. Used circular LNB "2" stands for Left and "3" is Right. On the same LNB also Horizontal and Vertical transponders are locking and show picture. Antenna- SMW-OA-1600
Archived-1
Persona non grata
uk
Hi, all this L R etc is all new to me, I was just checking this signal and it appears that I can get R by using H is his correct please.
12092 Rtp ER20Russia
NTV Plus
DVB-SViaccess 4.0
Viaccess 5.0 27500-3/4 112-21
5.5
That's impressive, of Eutelsat 36B you're receiving both Sub-Sahara beam (12073 V) and Russia beam (12092 R)!
A normal LNB can also receive circular signals (L or R) with 3 dB loss, either using H or V.
In this case, you can receive 12092 R only when using H, because that supresses the interfering 12073 V.
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
that's impressive martin that you are getting the dstv package and the Russian package !!!!
Martin! You're getting a Russian beam of 36E! That's the first time I've ever heard of anyone getting it in UK. If you get a circular Ku LNB, or still a depolariser plate in the throat (an old credit card will do), I wonder what else you'll get off it.
I wonder too, but in this particular case a circular LNB might be worse!
Because then 12073 V will only be suppressed 3 dB instead of "lots of dB's".
12092 R is also rather special because there is no nearby L transponder that would kill reception when using a linear LNB (assuming Eutelsat 36A is much weaker than 36B ).
But a circular LNB sure will be worth a try. Wasn't it you CJ, that tried a circular LNB on 56°E a while ago? ;)
Archived-1
Persona non grata
uk
I think I am getting both Russian and Sub-Sahara beam from 12073, if you look at my screen grab below 0043 its the same TP but different pids, I was going to send for one of these Invacom QPH-031 https://www.google.co.uk/?gws_rd=ssl#q=invacom+qph-031+quad+polar+lnb
will it do the job here please ?
dscn9553-jpg.82368
Above screenshots are 12073 V. What you're tuning on 12073 H is actually 12092 R.
The Invacom QPH-031 is for US market and for circular will only cover 12.2...12.7 GHz, so no good here.
The Inverto IDLB-SINR41-H1060-OPP should do instead, covers 11.7...12.75 GHz with our standard 10.6 GHz LO:
http://www.inverto.tv/products/product.php?section=1&id=47&cat=29
I think someone on this board from UK has an unused circular LNB (this one?) lying around, I forgot who it was...
nelson_b
Contributor
Hi - well done on spotting the Russian beam - martin
had to try this one myself today having tried and failed a number of times in the past --
and indeed i have this one too today :) :):)
12072 is in my ch list - so must have been seen in the past - and is also locking today :)
As with the weak tp,s, on 7 West and 31.5 West that came to light recently these 2 will not lock using a C120 and CM feedhorn --- and are only locking using a standard l.n.b.,f ????...an inverto black ultra is on the 1.8 at the moment .
Now having serious doubts about the value of the c.m. feedhorn for fringe k/u/ reception :(
pity i have to work this afternoon i would love to play further .........................
Archived-1
Persona non grata
uk
View attachment 82379 View attachment 82380
Great stuff nelson, well at least your getting more now from your setup, I now have a TM 01db LNB for testing I will post my results when I find the time to do some tests :)
nelson_b
Contributor
yes - the recent comparison tests with you ............ have shown up an issue with the c.m. feedhorn versus a standard l.n.b.,f --- most of my own past comparing tests were done on the old turksat east beams and the C120 + feed was always the best of the two at the frequencies i was using there ??
all this seems to raise more questions than answers o_O
RimaNTSS
N-E from Riga
C'mon folks! It is impossible to get lock on any cyrculary-polarised transponders from 36*E in UK on 1,8m antenna, even more by using universal LNB. No way!
OK then RimaNTSS, martin-f and nelson_b are both lying, and I'm in the conspiracy as well. :-rofl2
RimaNTSS
N-E from Riga
I did not say so. They can not do it! But everibody makes mistakes.
In offered screenshots I did not see any sighns of circulary-polarised signal reception.
I am definitely surprised but the EPG is carrying Russian text and NHK World is on Russian beam. There's no doubt here.
RimaNTSS
N-E from Riga
That statement also refers to me BTW.
I do not know why NHK World TV is lockable un UK, then another channels from same transponder also should be in the list. Perhaps something is wrong with lyngsat.
Martin/Nelson, could you post a screenshot of the channel list on 12092?
