fridge on blink following powercut
My uncle still uses my grandmother's fridge from the 60's at his dacha. Has never skipped a beat. Everything made these days is pure brown tosh.
This one, actually....
That's why I buy cheap brands like Bush, as they seem no more unreliable than Neff, Smeg and all the other posh stuff.
And it doubles as a living fire upon failure!
I thought as much but it hurts my brain to call it thus since it has no fuses :) (all breakers and GCDs)
Unité de consommation (Consumer Unit)
Mind you, that Google Translation is probably too literal and more likely to refer to the size of a portion of Moules.
hairybadger
Bricoleur
46.1N 6.4E
see sig
We've just had 10 years out of a Bosch dishwasher and fridge-freezer, although we had to replace both at around the same time. Customer service is an interesting, experience though... :(
I thought as much but it hurts my brain to call it thus...
I am very far from being fluent in French but just occasionally the French word for an object comes to front of my brain and pushes to one side the English one I'm struggling to say. I sense your pain.
sonnetpete
wordpress.com
Normandy, France
Wandering slightly off topic, we went to Darty to buy the new fridge freezer and had a Gorenje (manufactured in Slovenia I think) 'retro' one in mind. We enquired about said product and despite it costing more than the one we did buy, the manager warned us off it. The ones he had sold all suffered with failing door seals apparently.
Tururu
Assembled with recycled parts
Recycled as the owner.
I've put surge protectors on every fuseboard (is this the word? despite being a native speaker of English I've spent a long time in France and subsequently some of my vocabularly, principally concerning houses and babies, is primarily French :) The tableau éléctrique in any cse). Sensitive equipment (not the fridge! :( ) is further protected by local surge protectors. The tinfoil hat helps as well :)
Creo que confundes los viejos fusibles/placa de fusibles que protege las lineas de alimentacion.
Actualmente usamos magnetotermicos, fusibles que disparan por consumo (exceso) o por cortocircuito, son rearmables.
Una foto para no liarnos.
Empezando por la derecha.
Interructor generar, diferencial, magnetotermicos para cada circuito (N+L [Neutro + Linea]).
Surge protectors = protectores de sobretensión = parasurtenseurs.
Parafoudre — Wikipédia
Los protectores que comento, para los picos, son estos (para el cuadro electrico general de la casa).
Internamente los tienes de varios tipos, en general, pensemos que son 2 electrodos encerrados en una ampolla de vidrio, estan ajustados para por ejemplo salte un arco electrico (chispa) entre los electrodos a 420 voltios AC~, tenemos conectado en un lado la linea/fase de alimentacion y en el otro la toma de Tierra de la casa.
En otro descargador el Neutro y en el otro lado la toma de Tierra.
Por ejemplo, cualquier tension por encima de 420 VoltiosAC~ la manda a Tierra para que no dañe la instalacion.
La intensidad soportada por el descargador, esta indicada (muchos modelos/intensidades).
Tambien tienes pequeños protectores/descargadores de enchufe (Varistor + fusible de X amperios [suele ser termico tambien]).
El enchufe tiene que tener toma de tierra (importante).
I think you confuse the old fuse / fuse plate that protects the power lines.
We currently use breakers, fuses triggered by consumption (excess) or short, are resettable.
A photo tiing not.
Starting from the right.
Interructor generate differential circuit breakers for each (N + L [Neutral + Line]).
Surge protectors = = parasurtenseurs surge protectors.
Sunscreens that comment, for peaks, are these (for general electrical panel of the house).
Internally have various types, in general, we think that are two electrodes enclosed in a glass ampoule, are adjusted to such skip an electric arc (spark) between the electrodes at 420 volts AC ~, we connected on one side line / phase feeding and the other grounding of the house.
In another downloader the Neutral and on the other side making Earth.
For example, any voltage above 420 ~ VoltiosAC sends to Earth to not damage the installation.
The intensity supported by the downloader, is indicated (many models / intensities).
You also have small protective / unloaders plug (Varistor + X amp fuse [usually thermic also]).
The plug must be grounded (important).
PS:.Photos of the Internet as an example.
PS2: This in signing, sorry for the translation.
Tururu
Cuidado.
Consultar normativa local sobre estos temas.
Consultar electricistas locales.
No se admiten reclamaciones, tocar un cuadro electrico es peligroso si no se tienen los conocimientos necesarios y/o autorizaciones/certificados.
Watch out.
Consult local regulations on these issues.
Consult local electricians.
No claims allowed, touching an electrical box is dangerous if you do not have the necessary knowledge and/or authorizations/certificates.
Important soins.
Consulter les règlements locaux sur ces questions.
Consulter les électriciens locaux.
Aucune réclamation permis, toucher une boîte électrique est dangereuse si vous ne possédez pas les connaissances nécessaires et/ou autorisations/certificats.
