Holes in external brickwork
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
My dad has decided today he will move the position of the letterbox in the outside wall and so has drilled some new holes into the brickwork.
He has just left the previous holes, but I think this is a risk for water getting in and causing damp? What to people normally use to cover holes on brickwork?
Mix some brickdust in with common or garden mortar to provide a filling that won't show.
2cvbloke
Near Pontop Pike, Co. Durham
Brick coloured silicone...
satelliteman
Silicon sealant or ready mixed mortar.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Pictures will help
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Pictures attached.
Same answer as at Post #2
But do withdraw the old rawlplugs first.
Insert a suitable screw a couple or three turns then gentle wiggle and pull.
Archive4
Is that permitted on Sunday´s?
Best bet, after removal of raw plugs, using an acceptable method ( on a Sunday ), would be to buy a small can of expanding foam and squirt into each orifice. Allow to set, then remove any external expansion and cut back into said orifice about 5mm.
Then, using a flexible filler, mixed with some brick dust, repair to level on front of brick. ( Most " non shrinking fillers " do shrink, so allow for two applications )
That should do the job;)
Damp won't be a problem either way if you have cavity walls and the cavity is in good condition (not bridged).
