ADS-B / Flightradar 24 setup
The 32 segments twig is not working as well as I hoped.
Perhaps because it's Sunday, there is next to nothing out there, or I have decreased my range, only time will tell.
Your mlat coverage looks much better now, since your little tweek to your twig :)
Did you check the continuity through the twig with a multimeter as you built it? If not you may have a duff connection somewhere.
That was quick - it takes me bloody ages to get the insulating tape off :D
Icons for CVK Cavok Air Ukraine & LWG Luxwings Luxembourg
  • CVK.zip
Icons for NAT Nato Ops & FLJ Flairjet private airline
  • NAT.zip
Icons for 2 Maltese operators
VJT - Vista Jet
MLT - Maleth Aero
  • VJT.zip
The bloody antenna has sagged over to 45 degrees again. I shall be replacing the plumbing pipe with 6 foot of stiffer plastic electrical conduit this weekend - the plumbing pipe will never survive the winter storms up here once it gets a bit of ice on the plastic :D
Range has dropped right off to about 40 miles again :(
Archive-8
Have you considered using some Wooden dowl to zip the aerial to before putting it in to the conduit?
2m of conduit in b&q was less then £2, and so far it's stood up to the wind and rain.
Something a bit special went over this morning - at 60,000ft! :)
It does strike me that its not a very good spy plane if any Tom Dick or Harry can see its around using nothing more than chopped up tv aerial cable & a 15 quid usb dongle :-rofl2
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Point taken....................:D:D
Cue "Trump Force One" on a visit to his Golf Club .....
Apparently the U2 landed at RAF Fairford mid morning.
1090 uputronics amplifier arrived - now I need to order the correct selection of interconnects.....
Over the xmas holiday I'll be seeing about getting the antenna up properly & moving the dongle & amp to the far end of an active usb extension..
:-lmao
Do I not like that.
