MCelliotG
- May 10, 2015
- TBS 5925, Mut@nt HD51, EDISION OSMINI, MABO 130X144, DRAGONSAT DS3000 LED MOTOR, INVERTO BLACK ULTRA TWIN LNB
- Thessaloniki, Greece
T2-MI on SatDreamGr images detailed guide/tutorial
1. Introduction
T2-MI is a special transmission method where a whole DVB-T2 stream is capped inside a data pid of a satellite transponder that is used to feed a terrestrial DVB-T2 transmitter. Until now, only some selected software was able to decapsulate these streams, notably for PC.
The SatDreamGr team made possible to implement this decapsulation to its supported Enigma2 receivers. So far this is done via the astra-sm project which works parallel to Enigma2 as a process, with the difference that it can now be done completely by the receiver without the need of an external device like a PC. The channels are being decapsulated internally as a stream favourites bouquet and can be viewed as regular channels with everything that there is inside the transponder stream such as EPG, teletext, audio streams etc.
The philosophy includes the data channel, which can be tuned with the receiver’s tuner (unless it’s also a multistream transmission, which requires a USB tuner like TBS) and acts as a feed for the T2-MI stream. This stream becomes an input for the astra-sm process, and with the help of a special script and a configuration file can be output as a stream package via internal stream relay. Note that this is the same way Powervu works for E2 STBs that don’t support direct emulation. The stream relay can then be stripped to separate channels that will compile a favourites bouquet which will work as a regular ready-to-view channel bouquet in the E2 receiver.
In this tutorial, I will show a complete step-by-step guide that will help you tune to these T2-MI streams and configure them to use on your E2 STB using the SatDreamGr image.
2. What you will need
a) your E2 STB
b) the SatDreamGr experimental image which can be downloaded here
c) Dreamboxedit on your PC for editing the streams and bouquets as required
d) a UNIX editor (like Notepad++ or UltraEdit).
e) an FTP client to connect to your STB (like Filezilla or FlashFXP)
f) a telnet client for certain commands (like Putty)
3. Getting the feed channel
Every Enigma2 receiver when it gets tuned to a T2-MI transponder will not download the channels directly (although this automation has to be implemented in the near future). Instead the tuner will lock and download a data channel. In the following example we used a T2-MI transponder on the C band of Express AM7 satellite on 40E.
In this image you can see that this frequency (3685L) is tuned normally with the internal tuner.
Now, scanning the frequency downloads the data service (it might take a while).
This data channel will act as our feed, as it contains the T2-MI stream. In 99% of these transmissions, this stream is contained in pid 4096. In order for the E2 STB to have it directly visible to the user in their channel list, it must be edited in the lamedb. There are two options; either direct lamedb editing (hard way) or editing via Dreamboxedit (easier).
With Dreamboxedit, the data service will be edited to look as a “fake” TV service (visible in the list). The pid 4096 has to be added manually too, as a cached pid.
After downloading the data service, FTP the channels to Dreamboxedit on your PC and locate the data service you just downloaded.
Click on the service and you will see a screen like this one:
Now change these parameters:
Name: input a descriptive name for the fake service. This is important as it will affect the configuration later on. In this example I give the name 3685L T2-MI.
Service Type: 1 (TV)
Check the K (Keep). This is also very important, so that the service will not be reverted to data on a future satellite scanning.
Extra parameters: add c:151000, where 15 is the cached index and 1000 is the hex value for 4096. This will cache this pid in the lamedb, and will provide all T2-MI data.
Click Save.
After this editing, the data service reference will change to 1:0:1:320:32A:0:1910E65:0:0:0:
Keep this service ref in mind, as it will be used in the configuration too.
After editing you can send the entries back to your STB. Make sure to completely reboot the STB after sending, and not just reload the commands, in order for lamedb changes to stick.
Now we are ready for Part 2 of this guide.
1. Introduction
a) your E2 STB
Click Save.
