vma
- May 17, 2007
- Location
- Portugal
- Website
- vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
- Portugal
Windows XP was never supported and I do not have plans to do so - it is a discontinued operating system, which should not be used, at least not connected to the internet, as vulnerabilities are no longer patched by Microsoft.
Anyway, it seems that older version do run under Windows XP if the .Net Runtime 3.5 or higher is installed.
I have put an archive of ALL versions so far on my blog. (on the bottom of the download post).
No support is given, but feel free to try which versions do run.
Regards,
Vitor
Regards,
Vitor
