- Mar 29, 2004
- UK
Can anyone please let me know if there is a supplier of "odd" size swing bolts? By "odd", I mean where the inner diameter of the eye is smaller than the thread diameter of the shaft. A Jaeger 1224 elevation bolt has a 12mm inner diameter eye and a 16mm thread on the shaft and I could do with a replacement for a 1224.
I could buy a normal 16mm swing bolt and shim the eye but if there is a supplier of the correct size it would be preferable.
Thx
Thx
