12 volt sky box
Mad Rat
65cm dish for Sky+ linked to all rooms, all with own remote and magic eye. Second box in home office (no multi room subscription just use card from main box if needed) 3rd box in bedroom Freeview in other rooms. Free cable in dining room Two 53cm mi
Leicestershire UK
:confused I need help! (my wife has said that for years)
I want a 12 volt sky box for use in the caravan, I know the Pace 1000 was designed for this but they don't seam to make them now. I have read that they are slow and problematic to. I have seen Pace DS430N and Thomson DS4212 for sale on ebay saying they are 12 volt but to be honest they look like home conversions, has someone just fitted an inverter in them? (links at bottom of post) Is their an official 12 box that only uses about 15w like the pace 1000 did because using an inverter just eats battery life. Are the Pace 1000's slow and problematic?
Also dose anyone know if those Squarial type dishes actual work?
http://cgi.ebay.co.uk/new-Pace-DS430N-12-VOLT-minibox-1000-tv-boat-caravan_W0QQitemZ220072230045QQihZ012QQcategoryZ76066QQtcZphotoQQcmdZViewItem
http://cgi.ebay.co.uk/12-VOLT-thomson-Sky-Digibox-brand-new-pace-minibox-1000_W0QQitemZ150083221516QQihZ005QQcategoryZ76066QQcmdZViewItem
2cvbloke
Near Pontop Pike, Co. Durham
By Squarial do you mean the original BSB squarials or the modern squarials like the Attisat FL500? :confused
Didn't think the Pace 1000 (also known as a Minibox) was problematic. I have one myself and haven't noticed anything amiss. Only S/H now I'm afraid.
Never heard of any 12v conversions but I suppose that it's possible. If they are are using a 12-240 volt converter then this will increase the battery drain a bit - I really would recommend keep looking for a Minibox.
Mad Rat
Leicestershire UK
Has ther been a problem with the server? since joining I have not been able to get on the site for 2 days, I can now but its painfully slow and keeps sending me to the wrong pages. Can someone in admin please help.
2CVBLOKE yes i ment the new squarials.
2cvbloke
Well, I can certainly say that modern squarials do work well, mine is an Attisat FL500, although I haven't used it for a while, and they work like prime-focus dishes which point in the direction of the satellite. They're usually about equivalent to 60-80cm dishes, depending on which one you get, but they usually only have a single output, so they're useless for things like sky+. They're also a bit pricier than a dish as they're a little more complicated inside... :)
Hope that helps!!! :D
devonbrown
4 systems. In Scotland Freesat with Humax Foxsat recorder. In Algarve 1.5 fixed Inv Quad LNB with 3 Pace 2600C1 and 1 Amstrad HD DRX780UK also 80cm dish with Inverto 0.2db monoblock LNB (19.2E/26E) feeding Technomate 5000CI+ usb.
Scotlandl and Algarve
I have a pace 1000. It is excellent. It has the same performance as the pace 2600c1, and has excellent reception qualities here in southern Spain. As they don't have an internal power supply the heat build up is negligeable. They command the highest price of any 2nd hand skybox on ebay,which perhaps shows their worth.
Mad Rat
Leicestershire UK
I think I will look around for a good used Pace 1000:)
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
I was looking on the web the other day and there was a uk company offering the minibox as new. Can´t see how but may be refurbished. There were showing something like 180 in stock. Sorry I can´t remember the site, but google and you may find it.
Good Luck
