16e in NW UK
homerjay
Spiderbox 9000HD, Super DARK MOTOR, 80cm Dish, SKY+ HD, HTPC w/7MC
Chorley, Lancs
hi all
ive seen info about 16e moving to 15.8e and having a poor signal currnently, but im really struggling to receive tring channels.
im sure the footprint covers all of the uk but i get 36% quality at the most, which means no lock.
im using USALS on an 80cm dish. ive tried tweaking all over the place and thats the best i can get.
i just need a couple more % for a lock.
can anybody manage a lock on tring from a similar location?
cheers
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Sorry hj, my wipermotor died 12 months ago so I am stuck on 13 East ATM, so am unable to check for you
homerjay
Chorley, Lancs
hey topper, after all those years of service too! :D
I.LuV.ManUTd!
80cm motorised with quad LNB, static 28.2E with quad LNB, VU+ Duo, DM500S, DM500S, DM800HD, Openbox S9.
Manchester
homerjay said:
hi all
cheers
You live 40 minutes away from me and I lock Tring at 70% signal with an 80cm dish ;)
D
deleted
Ive fitted a few dishes for 15.8e the last few weeks in and around Manchester and have not bothered with 80s as i only managed 50/60% max and if you take the weather into consideration even worse, i fitted 90cm and getting 75+%
satelliteman
What 90's are you using out of interest?
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
If I nudge the motor I get 40-50% in normal weather
fergyc
Northumberland
Sorry, that wasn't clear. 40-50% quality on the main tring transponder
I.LuV.ManUTd!
Manchester
Hey,
I may have some work for you soon, you seem a good guy from your thread.
Really it's tidying up my wiring mess.
Regarding Tring, I easily get 70% with 80cm.
D
deleted
Sorry for the delay in replying Satelliteman.
They are some ex stock fortec star my supplier had but has no more so using 1mtr now
fergyc
Northumberland
If I nudge it to get Tring i lose DigitAlb and most of the other channels :S
I.LuV.ManUTd!
Manchester
Is the dish too small?
fergyc
Northumberland
Yeah but it's weird that I have to move it across 16e to find Tring and then back to get DigitAlb etc.
I.LuV.ManUTd!
Manchester
dale094 said:
I luv Man U too m8
what dish are you using
I was at the game yesterday, did you go? :)
I'm using a standard 80cm dish, nothing special ;)
hexah
Hadrians Wall
It is due to the three satellites around 16e being strung out, old and with misshapen beams pointing to SE europe.
Eutelsat W3B is due to be launched at the end of October and will be quickly put into service, so normal service should be resumed sometime in November / December.
The footprints are here.
W2M is almost brand new ;)
hexah
Hadrians Wall
Just the odd scratch or two... O-Ha
