Archive-8
Is that the direct lnb just strapped on the dish? If so I might have to get one :-)Also receivable on the DirecTV LNB with an unmodded SUP.
Very good scopus, haven't tried Band B with mine.Also receivable on the DirecTV LNB with an unmodded SUP.
I will have a look at ebay tomorrow for one. Thanks for your help.Very good scopus, haven't tried Band B with mine.
@Chris1979
Check out the http://www.satellites.co.uk/forums/threads/the-directv-sl3k4nr1-03.162534/ thread, plenty of info there for using one those LNBs. The '03' version seems to be the more sensitive one we find. There's usually one or two available from the US. Search for 'sl3k4nr1-03'
Find KA LO Freq - KA Freq. Add result to KU LO Freq.I will have a look at ebay tomorrow for one. Thanks for your help.
How do you work out ka freq to ku freq? Is that as easy as the other way?
ACM AOL feeds Chris. Been there for ages.Tbs Card has just found this:
1=10958,H,45000,12,21,|9.8 (8.5) dB
2=11218,H,45000,12,21,|14 (12.7) dB
3=12068,H,45000,12,21,|13.9 (12.6) dB
But no picture, I guess it must be data of some sort.
First time I had seen them. Thanks. :-)ACM AOL feeds Chris. Been there for ages.
Happy hunting, I am just about to go and tweek my dish/ remove an lnb, & line up the brackets.I made a bracket Chris, lowered one of the boom arms on my Channel Master 1.8, so it sits offset by 4 degrees at the side of the Ku, works well.
Is this the sort of thing?I will have a look at ebay tomorrow for one. Thanks for your help.
Thanks for that, :-) just ordered them.Very good scopus, haven't tried Band B with mine.
@Chris1979
Just checked on my box and all is normal.The two Avanti HD channels are now coming up as encrypted.
Glad you sorted it :-)That cured it..........
