45W (Intelsat 14)
Archived-1
Persona non grata
uk
DSCN3817.JPG I cant get digital 1 for some reason, I cant understand it I am not that far from ponti, iv tweaked the dish and got radstv coming in @ 80%,
I love the test card on radstv atm:).
As promised, I have wrestled command of the 80cm Dish from SWMBO and get:
RASDTV 11609 H 1851 with SNR 67%
Al Nassr TV Chad (Digital 1) 11488 V 1237 with SNR 70% and overmodulated Audio!
I'm also registering
11454 H 2314
11674 V 1028
but no Channels.
Edit: They are Data TPs.
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
Something very strange is going on. I can get RASD TV no problem (72% quality) on both my Technomate and TBS card, not a sniff of the data transponders or Al Nasr TV here at all, despite being only a little south of you. I'll try again later on my Technomate but suspect I will have similar results.
It is dead stable - but martin isn't getting it either.
And I'm only using the 80cm.
Weird ...................
remlap
Wales
Oddly I had it this time yesterday, it was gone later in the evening then now I have it again.
Archived-1
Persona non grata
uk
does everything look in order here please ? apart from no signal lol.
Can't see anything incorrect - does your Rx resolve such low symbol rates?
Channel is definitely there right now.
Archived-1
Persona non grata
uk
That could be the problem tivu ? i can not see any reason why i should not get this/some signal movment, i will have to try the topfield :-).
Yes, can't think of any other reason. Well outside DECT interference scope.
Archived-1
Persona non grata
uk
i will try the topfield or pc card after tea and report back thanks tivu :-).
pontiend
Contibruter
south yorkshire
If it will help here is the .xml file on my Alien2.
<transponder frequency="11487000" symbol_rate="1237000" polarization="1" fec_inner"4" system="1" modulation="1"/>I will try to load the list.
Eer it has uploaded but needs to open in notepad.:)
They are both on now .About 20 minutes ago digital was showing a test card.Or something like that.
  • 45w transponders.txt
Archived-1
Persona non grata
uk
thanks ponti, ive tried 2 stb now t/m 6900 and a topfield tf7700 and nothing, i will have to check with the pci card at some point.
thecaretaker
Lat: 50.86021 Long: 0.52973
www.thecaretakers.net
VU+ Ultimo, Duo2
85cm Fracarro Penta dish
Inverto BLACK Ultra QUAD
South East Coast, England
Digital1 is a very odd channel. My VU Ultimo scanned in the channel, but when I switch to the channel it can take up to 2 minutes before I get a picture. Once it has, it comes through at about 20% and rises slowly to 60% but the picture is fine . I assume this is the auto gain control (AGC) working on it. Just switching to RASDTV (which comes through immediately) and back to Digital1, I have to wait again.
Anyway, nice to have another channel at 45w. ;)
It behaves perfectly normally on the Skybox F3!
pontiend
Contibruter
south yorkshire
Both my TM5402 and my Alien2 change normally.
I am on the alien2 100cm dish now.
RASDTV SNR 66% BER 0. Digital 1 SNR 64% BER 0
remlap
Wales
Steady signal in this heavy rain we're getting now, but have decided to go round to hot bird to watch TVE 24 Hours
The problem is the very low symbol rates - it takes time to "build up" the signal due to low SR hence you seeing the slow rise in SNR. Don't think it's anything to do with AGC.
pontiend
Contibruter
south yorkshire
There is a problem with the TM blind scan.The blind scan finds nothing on that satellite,even though it has the TPs in the satellite list.Doing a single transponder scan or normal scan finds them.As Captian jack says. I think that it is down to the scan timing out before a signal can build up.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
my TM6800 reacts the same.
