46E (Azerspace 1)
Archived-1
Persona non grata
uk
i am using an old technomate 1500 c/j, @ laser you wont get anything from it its a data channel m8.
Laser
Thanks for letting me know it's a data channel. Good to see a strong signal though. Just gone off as I am typing this ....
Archived-1
Persona non grata
uk
yes indeed nice to see strong signals, do you get the 10.975h 28.500 tp
Laser
Just tried again 10975H 28500.... Not a whisper. Too far south I guess.
BlindFaith
TBS 5925
seems to be off again. No signal here on 11134H
10975H shows a signal but apparently not enough for a lock :(
Archived-1
Persona non grata
uk
yes signal went when laser was typing blindfaith on 11.134, i keep checking 10975 no chance of a lock only 20%.
Laser
Be interesting to see which channels pop up on the European Beam :-shifty
Not a squeak here this evening
According to a post on DS 11175H 10000 was reckoned to be active earlier but nowt on that one either.
11134H 10000 just lit up again -
SI 90%
SQ70%
80 cm dish
No channels on it.
BlindFaith
TBS 5925
100% null packets!
Laser
Yes. 11134H 10000 on again.
Signal level 98%
Signal Quality 82%
With the 1.2 C.Master
I reckon my Uno doesn't know what to do with this odd transponder... Strange that everyone else is getting this except me. Laser - where are you based?
BlindFaith
TBS 5925
This is an empty carrier. Without meaningful PIDs scanning will fail. You have to use an analyser like TSReader or TransEdit.
Right, but I should still be able to "lock" the signal, right? I.e. the modulation is still there to latch on to.
Archived-1
Persona non grata
uk
i just monitor it like this,
Laser
Doesn't seem as strong today. Only 68% SQ on 11134H 10000 on CM 1.2m
Captain Jack. I am based near Gloucester
OK, well I am in Bristol, so not really that far away from you. I guess I need a better receiver to show me quality even if it's not locked. Enigma2 receivers won't do this.
It was showing 70% on my F3 again earlier. Still no channels scanned tho.
Anyone seeing a lock on an Enigma2 receiver?
Archived-1
Persona non grata
uk
i dont think we can lock this c/j ? its just a case of monitoring it with db or % are better devices ?,
your post here is showing some signal @ 4.5 db on the 30.5e thread
http://www.satellites.co.uk/forums/topic/158239-305e/?p=840265
input the tp and see what you db shows,
unless i have got this all wrong sorry if so :{ are your not getting any db ?.
