Dggrr
- Sep 2, 2006
- Age
- 69
- VU + Zero, Triax TD88, Technomate TM2600 (Plus CM 1.2 in bits behind the shed)
- SE
Anyone have some to sell or can recommend a good source?
I plan to put a TM-2300 on my Gibertini 1.2m (it's a very sheltered spot). Currently have 2 lnbs for 7E & 10E.
I cut the existing 4" mast at the right height for the fixed dish but need a few inches higher for the motor setup.
So am planning to address 2 issues with a smaller mast clamped to the current 4" mast:
1. Technomate specifies max size 65mm, and
2. The current mast has veered very slightly off true vertical, probably from the roots of trees, so will use some shims.
Metals4u sell 3m for £221.10 inc VAT https://www.metals4u.co.uk/materials/mild-steel/mild-steel-pipe/pipe-galvanized/8690-p - Ouch!!
I'm in the HP4 post code (Herts/Bucks/Beds border).
