7025 pin code
CROSSBONES
S.Wales
What is the factory set pin code? I have tried 0000 but its wrong!
Is there a way of changing it?
I am using nablio black hole
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
CROSSBONES
S.Wales
nope tried that:confused
dig deep
Prince of Birthdays
Sweden
Well, it was a good try :) I have a 7020 and a 500 and both have the same pin so I guess You must have changed it.
A factory reset will fix it I think and a good backup will fix the decoder after the reset.
CROSSBONES
S.Wales
I bought it 2nd hand, I should have done a reset when I bought it, mailed the guy whom i bought it from but he cant remember it either:confused
Thanks any way Dig;)
