ABS 3A @ 3° West
blademedia
Sky
Smile of a child back on the 10718 H 10000 mux
blademedia
Sky
Sky sports 3 started on 11580 H 27500 Mena beam, I can see it no lock
ocean04
Vaasa
Western Finland (63N 22E)
Currently there is one channel 11580H (not sky sport)
Anonymous_1
Maybe not so wrong.
Unfortunately I can t lock it and check this mux by myself but according to the ID and the previous test at 26°E few months ago on 12380 H .(Sky on OTT @ 26°E) Sky sports and more channels are probably embedded in this stream.
Just an idea...
blademedia
Sky
I know some of you don't like offset dishes, but locked this in the Midlands on the CM1.8 with the little Freesat receiver.View attachment 104319
I like off set dishes I have enough of them 2.4 1.8 3 x 1.2, My 1.2 can see it but wont lock it, as for the 2.4 getting slightly more signal than that, its not correctly lined up and using a 20 yr old lnd, plenty of room for improvement when the rain decides to stop.
Sure you will get a good result when tweaked. Quite pleased with my results seeing as I'm not using a pukka CM feedhorn and C120 LNB
blademedia
Sky
Might not in KU band scopus, it could perform poor if its only spun for C band, if it doesn't perform well in KU it will be coming back down, Could you check weak signals from 7W please and post up for me to check, noticed a thread in fringe reports
Will take a look..
blademedia
Sky
A few feeds active here at the moment
Lexzie
TBS 5925 USB-tuner
The Netherlands
Never had any signal on the MENA beam (with 1.2m and black ultra LNB ).
Only Europe beam, so just the test card from HELLAS SAT @ 3W.
ocean04
Vaasa
Maybe not so wrong.
Just an idea...
Now 11580H is Sky sports 1
Blind scanned 10718H today on MENA beam at 3 dB. Shame 11580H doesn't have the same spillover!
VodzigorLans
Setup is down atm
RU, Saint Petersburg
For 2 days i dont Hellas Sat test card here... i wonder where did it moved to?
Feeds still reasonably strong here but nothing from Hellas Sat test for nearly a week now,
Blind Scans of 3 west have not revealed any new frequency so I assume that this test card on 12517 V 2222 is no longer being transmitted.
Archive-8
Is 3°w still a dead duck? Or has the Hellasat test card gone completely?
As I need a signal I can try and line my dish back up properly.
