Advice Needed Adaptation of the GTP-1800AM 36V HH motor to Gibertini 150 cm
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
I supplied the GTP-1800AM engine. I want to adapt Gibertini 150 cm. I am open to suggestions.
Thank you.
Is the Gibertini with, or without polarmount ?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Once I've made adaptation plate for Jaeger motor to be able to hold Channel Master antenna. I think you can go more or less the same route to marry your GTR to Gibertini.
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Any other suggestions?
anto@
italy
this is my solution on the gibertini of a few years ago
  • 2023-08-27 19_14_48-Kit adattatore Gibertini 125-150 SuperJack HH 1224 _ STARSAT, La TV dal Sa...png
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
nice work mr. Anto@.
(Edited for clarity)
If the o/p requires a quick fix then inverting the two HtoH stand-offs, connect via spacers the outside of the Gibertini declination plate.
No reason to make anything except some longer than usual bolts (or perhaps four bespoke ones).
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
I adapted the Gibertini antenna mount by drawing it from scratch and laser cutting it. (sheet metal 3 mm)
I'll assemble it after painting. I'll write the results.
RimaNTSS
N-E from Riga
Could also be made of INOX. You will need to paint it good.
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Yes, it could have been INOX. It was a bit expensive, so I went cheap. :rolleyes:
Very tidy! I gotta get myself one of these laser things!
dreambox1959
46.3N-4.3E-FRANCE
france
how did you make this schematic ? what software did you use for this ?
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
Unfortunately, the project has been temporarily halted.
The legs that hold the large gear inside the motor that allows the antenna to rotate were cracked by the weight of the antenna.
The lower part of the motor is cast.
Cancellation until we can make it more durable.
That is a shame. I had a similar alloy failure of a much earlier motor, the casting is rarely forgiving.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Strange that the motor could not withstand the weight of the gibertini 150. It is not that heavy. The motor appears to be of poor quality. I have had the same antenna for more than 2 years without any problems - the antenna is powered by a Diqec Amiko motor. The prototype construction of the Diqec motor is indeed made and the antenna is balanced.
Those H180 motors are rubbish. A quick search on this forum will reveal that most people are not happy with its performance, construction quality and features (no east/west limiters...). It needs a lot of work for it to be acceptable.
Manikm909
Small'ish Dish Man
Kent, UK
its a shame no one else seems to make them anymore. we need a reboot of the Jaeger SMR-1224
