Amateur daft question
villafiller
Nokia 9650
Northern Italy
I'm trying to setup my system but have a mountain behind the house with a borderline line-of-sight at 35 degrees of elevation to hit the Astra position.
I've been able to download channels but can't view them - Does downloading them mean my line of sight is OK and therefore something else is wrong with the setup?
Cheers,
Andy
Which Astra satellite are you trying to receive?
If you have them, then you have signal.
Problem is if there is part of the dish obscured, or the transmission is bouncing off the mountain as well as coming in directly, then you will get little or no useful signal.
You will almost certainly have to reposition the dish
villafiller
Nokia 9650
Northern Italy
Thanks for the replies - I'm trying to hit Astra 2A/B 28.2
Lat 46, Long 12
I had it at 157 degrees magnetic azimuth and 34.7 elevation
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Lat 46, Long 12
And what size of dish are you using?, that a very important detail from Italy where your profile says you are.
Also what channel were you trying to open? was it a FTA transmission?
