BBC 27.5W?
jacko
tenerife
[sub]still no luck with the spiderbox.changed the icon in the channel list so that theyre showing[/sub]
[sub]scrambled.rechecked everything but the channels are not clearing.[/sub]
[sub]@blindfaith, is there anyway that i can overcome this problem you wrote,[/sub]
The BISS ca_descriptor 0x2600 is also missing.
BlindFaith
TBS 5925
Well, it was worth a try. Your box needs a different patched firmware..
robbieb43
London: 1.1m Triax, Stab 100 + 3 fixed 60cm, VU+, Qbox Mini HD, DM800, Echostar HDS600
Canaries: TM 5402, Dm800HD, Qbox Mini HD, DM600, 1.4m, 2 x 1.2M, 1.0m, 0.9m fixed.
London and Canaries (Costa Teguise)
Sorry folks, just had to show off. Working fine on DM800 HD.
SNR is normally 100% but it's light rain here. The signal is pretty much as strong as 28.2!
Hi Hixxy1 - thanks for posting part of the answer to my question already as you are showing one of the MPEG4 channels. Can you tell me what tuner you have in your DM800 as they generally seem to be arround the following spec:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK), DVB-S2 (8PSK, QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud / s, SCPC / MCPC
DVB-S2: 10 to 31 Mbaud / s (8PSK), 10 -30 Mbaud / s (QPSK)
I wonder if I have a gap in my understanding of the way I should interpret SRs for QPSK or the way I am reading L**gsat?
Rob
jacko
tenerife
i have the software ver f5.41 ldr ver 00.31
hardware ver 01.20.rm ptc ok
march 29 2012.
is it just a matter of trying the different firmwares or is there one
i should be looking for.
thanks
Bricked my Skybox F3 after setting Encryption Flags in the Channel Edit Tool !
(Now recovered, fortunately - but my experiment is definitely at and end ..........................)
jacko
tenerife
@blindfaith,i am a bit confused about,
if this was missing would i not be able to add the biss keys in the
revelent section.
How to add Biss keys
Go to Menu - Key Edit -Press OK - CAS Type > BISS
Press add (yellow button) - add the frequency of the channel and then put the keys on the key data pressing OK
Exit -Save -OK
Save again -OK -Exit.
Wait for channel clear
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Just got these channels easily with the Technomate 5402HD, Highly recommend it.
jacko
tenerife
giving it another day with the spiderbox then if i dont get any of the channels to open,
then i am ordering a tm 5402hd
BLUEPLATINUM
Maspalomas, Gran Canaria
Was it a very complicated process to bring the channels in ?
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
I had already installed a special version of operating system to allow me to enter the BISS keys (which was a doddle to install), but no it took minutes.
craignigel
1.4m PF Fagor fixed dish Invacom quad C120 LNB. Amstrad SD Sky Rx 1 feed with Sky Subs. 2nd feed via DISEqC switch to my DB500S, 3rd to a Ross HD Rx.The switch also connects my 1m dish with a Motsat3 motor to DB. Satlook Micro G2 meter
Los Balcones, Torrevieja, Alicante, Spain and Moortown Leeds UK
Has anyone found any other receivers besides Technomate 5402HD and Dr HD F15 (and I guess F16) that will open these channels? I'm thinking about replacing the old DB 500, SD. I think that its had its day.
Hixxy1
East Midlands
Rob
I'm using the new version Alps tuner but I've read that older BCM tuner also works.
BCM4505 works OK. Plugged it into to my DM8000.
jacko
tenerife
hello ,
going to order a technomate 5402 hd tomorrow from am*zon.
have noticed on other sites theres a
tm 5402hd super ci+
tm 5402hd super+pvr
tm 5402hd.
are all these receivers the same receiver but just advertised differently.
i dont want to end up buying the wrong model.
the one on am*zon is just advertised as tm 5402 hd,
will this be ok to open these bbc channels.
thanks
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Vu + Uno (100%) and propably VU + Ultimo.
Humaxboy
jacko
tenerife
hello,humaxboy,i have just ordered a tm5402hd,
i failed on a spiderbox 9000 hd,but a have a vu+ solo,
so will give that some testing this evening,will have to
read up on how to enter the biss keys.also did you use
a channel editor for the vu+uno to change anything.
cheers.
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
Works fine on vu+ Duo, Uno and Ultimo, also been told working fine on Solo.
dxn
Estoril - Portugal
Prime-focus 2,10m, 0,2 LNB Black Inverto, TBS6983 dvbcard, Octagon SF4008 4K,
Dreambox7020HD, NOS cable 200mb, Tivusat, TDTsat Spain, TDT Portugal.
Estoril - Portugal
How to get it opening on Dreambox 7020HD?
I inserted the pids manually (Video,audio and PCR) with dvbedit program but channels don't clear. Can annibody help?
BlindFaith
TBS 5925
..you don't have to add pids manually. A channels search will automatically set the correct parameters. But you need an image with a working emu. Can't help you with that ;)
