Indeed.No way.. the CM 1.2m dish is far too heavy to sit on such a small motor. You'll need some pretty heavy duty bracketry and a 76mm pole.
strange - works really well from 973 km away in a quite different country...
Can I encourage you to state what sort of CM mount you have been offered (see posting above #5 above?)That said I KNOW NOTHING ABOUT THIS but am willing to learn
That said, the mount blademedia indicates would be just what you need.
But what about the dish you have been offered - are you sure there's not a mount you can take over there?
Probably just still observing the only true allegiance to Danelaw...Yes, it's a strange error message given I'm in the same Country as the Host!
Perhaps Yorkshire has become Independent at long last?
picture from seller
Yes, seems good condition.Looks in good condition, might be worth getting, just in case you decide to move to a property with an open, south facing, garden, in the ner future, which was the reason I moved house
Ah!rear of the dish
Indeed.
You need to consider that not only does the dish swing the centre of gravity back and forth all the time, but it also needs to survive gale force windws without budging a milimetre!
CM did produce a pole mount, which allowed the 120 to be attached to a 60mm (possibly even a 50mm) mount, but it's going to be almost impossible to find one.
The CM polar mount, and the normal Az/El mount requires a 3" (76mm) pole with open top-end (they fit at the end of the pole).
Here's pics of the original CM wall mount, although they are hard to come by.
Channel Master 120 set-up for 28.2E / Astra 2x
You can, however, buy other sturdy brackets for a 76mm pipe, eg. with Satellite SuperStore.
@Spiff had some experienec with various 76mm wall backets recently, perhaps he can throw in a few comments...
