Best receiver for aligning dish
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
Hokksund,Norway, Lat (DMS) 59° 46' 60N Long (DMS) 9° 58' 60E
What is the best receiver for aligning a fringe dish?
I have a Pace 2600C1 and it gets the signals, but it is a pain changing all details to see signal strengths
I would like to be able to change channel only and see the Strength Quality outputs.
Is there a receiver which has this capability?
satelliteman
Pace 2600 receivers work well on weak signals but using a meter is always better for dish alignment.
Most receivers have an option to check signal on any stored transponder.
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
ok. What make is a reasonably priced meter?
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
Sorry for the quick lazy response just now.
Do the 5 dollar meters with analogue display work?
satelliteman
Squawker meters are not good for precise setting up of large dishes in fringe areas as they have no way of band or frequency selection. They can though be used for peaking the dish in general.
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
Maybe an Openbox 810 is an option for you: _http://www.openbox.ua/receivers/x810/test.php
That's what many DXers use here in Germany for aligning and measuring. It's cheap, precise and very sensitive for weak signals. The disadvantage: It's not DVB-S2 capable.
Further information including lots of screenshots you'll be able to find at _http://forum.dxtv.de/wbb/board.php?boardid=79
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
ok. thanks for the info :-)
deepbluesky
You're welcome :)
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
Found out that if you change the default transponder in the installers menu and then pull the power, it stores the setting you have given it. This means you can just go in on the std menu and signal strength test for aligning to 2D
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
Humax Foxsat Freesat ...you cant beat that
doktorofsat
C BANDIT
QTH
KAON 570 with SUNNY on it:)
park_gate
1.8M + Pace 2600C1 spain
PO7 Uk and Moraira, Spain
Won't work as the box will revert back to the default transponder at some random time and you will have no way of knowing it happened.
For initial dish alignment use the default transponder set to a strong signal. For the next stage use the manual tune in the installers menu.
For the final stage adjust the dish just as the picture is starting to break up for best reception. You can't take too long on this stage as you probable only have a half hour window to do this.
You have to do the last stage with the picture as the meter is too coarse as it jumps in 10% steps.
The best meter in the world won't beat this final stage as you are align the dish with the equipment and difficult reception conditions that you will be using to watch TV.
Here is how I set up a disk for north Costa Blanca.
Signal Strength / Quality
  1. Press, in succession but without pausing, 4, 0, 1 and Select
  2. Press 5 (Manual Tuning)
  3. Enter frequency for required channel
  4. Select Find Channels
  5. Adjust azimuth, elevation, and then skew to get max. possible signal quality bar
Align Dish
Use frequencies in following order:
  1. Start with 12207V 27.5, 2/3 (2B south)
  2. Then change to 12480V, 27.5, 2/3 (2A north).
  3. Do azimuth and elevation, and then skew.
  4. Then change to Astra 2D BBC2 (10773H, 22, 5/6)
  5. Do fine adjust for min pixilation.
Warnings
  1. The Sky box meter can crash and just stop working. If the signal suddenly drops the box might need unplugging from the mains for 10 second.
  2. The manual tune option will timeout quickly if there is no signal so use the default transponder / signal test for the initial dish alignment.
Terry
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
Thanks Terry. I'll give that a go in the next few days. Like i said getting a 80/90% with single Invacom & 70/90% with a Twin MTI on the default transponder, but no 2D at all. I had 30/50% before with a smaller dish, so i'll keep trying
satelliteman
You could of course buy an entry level professional alignment meter and sure to get use out of it more than once. Everything done at the dish and no need for trailing extension leads with portable TV's :D
park_gate
I'm not familiar with reception in your location but if possible try aligning to a weak south beam transponder before going to Astra 2D.
Also if you get no 2D signal try the strongest transponder and best time of the day for your location.
If you are getting 80/90% on the default transponder I would say you are close and you only need to do small adjustments. You don't say if this is quality or signal strength so I would like to add go for signal quality and don't worry about the signal strength.
Have you got the right feed-horn to match your new dish?
You might also find the following site helpful:
_http://www.geo-orbit.org/sizepgs/tuningp4.html
Terry
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
HI, And thanks for all the tips Start with 12207V 27.5, 2/3 (2B south) Signal 60% Quality 90%
Then change to 12480V, 27.5, 2/3 (2A north). Signal 90% Quality 90%
Then change to Astra 2D BBC2 (10773H, 22, 5/6) No signal Tried 10818 as well no signal
The feed horn is correct.
What model Entry level professional meter do people recommend?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I personally like the Digisat Pro ..
LCD display ..
2v LNB inputs ...
Diseqc control ..
an adequate range of menu functions..
and around £50
damned good value..
rgds
VS
Ebay item
270484505462
if you want to check it out
park_gate
What time of the day are you trying Astra 2D? The signal will vary. I believe the best time for 2D your area is in the daytime so do the alignment then and in good weather.
Also I believe your horizontals are the strongest so try 10832H or 10891H and make sure FEC and symbol rate are correct (22 and 5/6).
Another trick is to adjust the skew on the default transponder so the quality is 30% then do the azimuth and elevation. The bad skew makes the other adjustments more critical and more likely to get the best setting. Also adjust the distance between the LNB and the dish for best signal quality. Then fix the skew before looking for 2D.
Terry
Is that something to do with prostitution?
Re: the budget meter, I would recommend either from my signature, or if that's out of your budget just use a good budget receiver like the Manhattan Plaza (which even has a digital squawker built in).
Hokksund
1.6m Offset
0.6dB MTI twin C120
Pace 2600c1
OK. I tried setting the skew off and aligning the dish and that help me get 90%Signal and 90% Quality on both 12207V 27.5, 2/3 (2B south) and
BUT STILL no 2D ...aaaaggh! Also tried 10832 H , but no signal. Is this possible?
I spoke with a guy earlier today who is 1 hour west from here and he gets BBC1 on a 1.2m dish, so my 1.6m should be fine...the signal weakens here around 20:00
i think i'll call an installer with a meter to come out and check for 2D
