danaddison
- Apr 21, 2022
- 100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
- UK
i have a bigish sat dish but i want one possibly 1.5m or 2m if i can get oneOP Gibertini 100 XP+ Inverto Black Ultra Lnb is the best for feed hunting in West Essex
Best Satellite Dish for Feedhunting in the UK?
i would like to pick up all satellites over the uk when feedhunting if that helps
thats good one lol
Fill your boots.
what do u suggest then 1.5m ?
ok, but still same question would a 1.5m dish be best?You were provided with my feedback in your previous "wanted" topic which now seems to be locked.
Although your previous topic has been closed, the content is still viewable.
It seems I was ahead of the game yesterday when I suggested to you that it may be best to close your "wanted" topic.
I think I will chance a few lotto tickets this weekend, predictive skiils seem to be peaking...
The answer to your question is to try. There are so many variables it's not a yes or no answer.ok, but still same question would a 1.5m dish be best?
okThe answer to your question is to try. There are so many variables it's not a yes or no answer.
Thread is still open my friendYou were provided with my feedback in your previous "wanted" topic which now seems to be locked.
this one is yesThread is still open my friend
Yes now it is.this one is yes
My policy is: the larger the better, especially for feed hunting.ok, but still same question would a 1.5m dish be best?
That depends EXACTLY what you want to have a look at. Also remember that many events are nowadays transmitted using ultra secure transmission methods that are not viewable to the average hobbyist. OR are transmitted using fibre links.ok, but still same question would a 1.5m dish be best?
i have both a sky dish and a 100cm (larger dish) but i cant find or lock onto 3w) and i want to be able to get feeds for glastonbury, rock am rim, download festival, radio 1's big weekend, Isle of wight festival, summer time ball, etc etc etc but most of them feeds are on 3w mostly and i cant get them with my current dises hence asking about bigger onesThat depends EXACTLY what you want to have a look at. Also remember that many events are nowadays transmitted using ultra secure transmission methods that are not viewable to the average hobbyist. OR are transmitted using fibre links.
For general feeds on 28E then a Sky dish will be fine for many of them. Low power feeds on obscure birds round will need something bigger & set up better
