C120 on a 40mm neck on a 80cm dish?
kamaleon
skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
str8 frum da wesside innit?
Hi folks
Trying to figure out how i could squeeze the extra few dB from my setup (there's the odd transponder on the odd bird that i can't lock to) i was wondering if it'd be possible and a good thing to do, to get a C120 lnb like the invacom quad or inverto and a separate feedhorn and mount it on my 80cm dish. Would this give me a better performance than a regular 40mm lnb from the same make? I can't really fit a dish bigger than 80 cm outside my window... :(
Cheers
I originally had an 40mm Invacom with a DIY 40 -22mm collar on my SMW dish. There was marginal improvement upon changing to a C120 invacom, probably because of slight inaccuracies in my homemade collar.
Don't think you'll see much in the way of extra signal.
kamaleon
Hi Llew, thanks for that feedback ;)
Hi think we might have too issues here actually:
- on the one hand I'm wondering if a C120+feedhorn would pickup more signal due to its bigger size
- on the other hand i'm supposing a C120 lnb is *better* than a non-C120 of the same model
do any of my assessments stand correct?
Same innards no doubt. Depends if you have a good feedhorn/dish match.
I dug out the feedhorn that I used to use with my SMW LNB, a match for the SMW dish.
kamaleon
Sorry mate, english's not me main language (i'm from jamaica inna africa innit :D). Say that again?
regarding the good feedhorn/dish match i guess i wouldn't, as i'd be using the feedhorn on an 80cm dish designed for 40mm lnb
I would very much doubt whether you will make any gain at all with a C120 feedhorn on a standard 80cm offset dish.
kamaleon
Hi rolfw,
why exactly would that be?
then there's the other issue - comparing a c120 invacom quad lnb, does it have the exact same components than the same invacom on a 40mm form?
The benefit of using a C120 feedhorn, is that when used with a dish to which it is matched, it should give near perfect dish illumination, so unless you can find a feedhorn specifically designed to illuminate your 80cm dish, I can't see any real advantage over an LNBF. Don't know about the Invacom innards.
Same spec for C120 and 40mm versions -
http://www.invacom.com/documents/Single_002.pdf
No doubt similar for twin etc.
kamaleon
Alright then, cheers for these infos.
S
satsid
hi m8,for a C120+feedhorn,i would not bother with anything smaller than a 1.2 meter dish.
sid
