- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
pedro2000uk said:The idea is to freeze the LNB and lose the heat elsewhere, if there was enough heat at the cooling site to actually effect condensation (and therefore freezing) then it would be really inefficient and you wouldn't want that either. .
Venting the LNB circuitry directly to the air ( or a bespoke dehydrator system) achieves this without the need to tranfer the heat elsewhere.
pedro2000uk said:I think butchering a small freezer or fridge / ice box could be the most practical for this.
That was what I was doing a decade ago, (working on a minimum cost also had its own advantages)
pedro2000uk said:BTW the thread 2 ...... snip .....describes the ‘use’ of freezing onto an element to trap vapour in another dehydration process demonstrating what I have said about condensation/ freezing- that is it is that good at extracting moisture out of the air. The process that is the main thread demonstrates the same problems and the air flow to a dryer element. That is that ventilation (in open air) is not anything you would want to do (unlike ventilation in a house for example) but a drying system in an enclosed environment is as I said earlier, if there is no vapour in the air it will not result in ice build up (or condensation).
Which comes back to the almost impossible task of removal of the humidity out of the air.
Optics (binoculars/telescopes) use a nitrogen or other inert atmosphere, but again this requires hermetical sealing, almost impossible where a microwave transparent feedhorn is a neccessity.
When carrying out tests, it was found that cooling of the air inside the feedhorn (and the feedhorn itself) also improved the C/N ratio, however the advantages were only 5%-10% that of freezing the LNB directly.
pedro2000uk said:It doesn’t say if they are using a cooler at the uplink or this is a passive system for general dry air/ minimal condensation. I have been involved in engineering/ chemical projects that, although not directly radio electronic cooling related, give you the experience of the kind of other problems that will arise trying to cool any object like that.
The worst issue may be condensation and ice in the feed horn/ wave guide and on the antennae (and down the connected coax). Until you try it you don’t know, the gains may out way the problems or have to be dealt with..
See above, but since the feed is in outside air, venting occurs naturally and the natural focus of the dish provides additional heat to stave off any permanent buildup of ice (in the UK anyway).
Did I mention that I sold dehydrators and Ice heaters for quite a few years in the commercial sector ?
pedro2000uk said:Lagging:
Dr Dish & RD100‘s.… cooling with freezer spray.. A far better test and result is to use lagging… when you use freezer spray to freeze a water pipe, you lag the pipe- you can’t do it without lagging - the lagging increases the freezing massively and retains it. If Dr Dish had lagged the LNB and pushed the freezer spray through a small hole instead, the temperature would have been far lower. The same goes for a proper setup and lagging will reduce condensation and freezing air bourn vapour as well as make it far more efficient.
Lagging does not reduce condensation, this is at the crux for correcting your responses.
pedro2000uk said:.... maximising a 1m rather than just getting bigger ugly dishes is attractive for a lot of people as well as bigger enthusiast’s ground based dishes gaining. Bigger dishes also have their problems too, weight, wind effect increases and needing 36v and far stronger gear all round etc.. this can help avoid some of this so it might be worth a bit of trouble.
Ugly dishes ?
