- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Not the engine itself, but the supplementary injector feed mechanism, the culprit sprung a leak on the No4 injector, between the main body and the engine sleeve. Nobody at Nissan could help as there are no seals (some 25 different shims though), so in the end I purchased two complete units from a breakers.
I have fitted one, and the van now starts with no leak from the original point, but I am not sure about the set of run off pipes running in series - front to back (is this something to do with keeping the injectors from freezing in cold weather ?) and whether it should be blanked off at one end , - a really nasty looking bit of soft plastic sits there presently - , or if it should be redirected into a a return pipe to the fuel tank. It is all low pressure stuff, and a finger on the end off the nozzle seems to stop the flow of fuel.
On the old Citroen 1.9 TD (Xantia engine) I owned some three year ago, the system had a return run back to another bit of kit (via a filter?), but the Nissan seems to have no such run off, it is just plugged.
The bit of plastic/rubber leaks slightly, and can be pulled off the nozzle rather easily. Is it something that has been fitted as a lazy Friday fit, or is it standard and needs to be made leakproof ? Last thing I need next week is to find I have blown a major pipe because of a botch carried out tomorrow morning.
Thanks in advance.
Thanks in advance.
