If your box is an original, you can get one from the dealer.
If it is a clone, you can get the part from many suppliers (try Google for a list).
Before replacing the part, try removing it and reinstalling it.
You can also try the damaged part on another box.
(to make sure that it is the part and not any component on the motherboard).
