Dreambox 920 owners - blind scan \ low symbol rate TP's
Manikm909
Small'ish Dish Man
Kent, UK
any Dreambox 920 who might be into feed hunting...? do you know if these STB's can lock low symbol rate TPs.
the search goes on for a second STB for me, other than a Octagon SF8008
I have the DM900 with the Dream Elite image and it found China Radio at 45W with Blind Scan quite easily45W.jpg45W2.jpg
Manikm909
Small'ish Dish Man
Kent, UK
thank you very much!!!
Satfaca
Melmac (46N, 14.5E)
Melmac
Probably depends mostly on the tuner (I have Si2169-D) but no problem even down to 500.
Besides other answers to your question,also read what low symbol rates I locked with DM920 UHD at #24.It's good to read the whole thread on the link.
Manikm909
Small'ish Dish Man
Kent, UK
that tuner is same as ZGEMMA H7S
that was useless at blind scanning, so its interesting...is the above result of a blind scan, or just showig low SR performance
MCelliotG
Thessaloniki, Greece
No, you got it all confused. The tuner is very capable at blind scanning, the driver was not.
I think it's all fixed in OpenATV now.
Manikm909
Small'ish Dish Man
Kent, UK
On what model? H7S ?
frankviana
Satellites/tv
Brazil
But fixed python code to show "start search: 00" and "end search: 60" or "start: 01 ~ end: 60"?
Manikm909
Small'ish Dish Man
Kent, UK
Manikm909
Small'ish Dish Man
Kent, UK
