Enigma2 receiver with both DVB-S and DVB-T
ledzgio
dreambox dm500s
italy
Hello,
I am looking for a good but not expansive receiver that supports both DVB-S and DVB-T modules.
Any suggestion?
thanks
samoloko
1.8 PFA
EU
Investigate Edision Mini OS
RimaNTSS
Some SAT-related hardware.
N-E from Riga
You look for good or not expencive? :rolleyes: Pay attention to Giga Blue receivers, good and relatively not expencive E2 receivers.
samoloko
1.8 PFA
EU
you can't beat Edision on price
ledzgio
dreambox dm500s
italy
Good an not expensive, both :) by not expensive I mean max 60-80 euro.
RimaNTSS
N-E from Riga
ledzgio
dreambox dm500s
italy
That it is not "not expencive" but CHEAP! And "cheap" sometimes is also "cheap" quality.
Well sometimes you can find cheap products at good quality. For instance, I have heard good things about the following:
OPENBOX V8 COMBO SAT+DTT T/T2 (around 70 euro)
CLOUD IBOX 3 SE COMBO SAT+DTT T/T2 (around 60 euro)
digi247
NW
see sig
Zgemma H2 supports DVB-S2 and DVB-C/T/T2 and is Linux and not a clone but does come from the same manufacturer as the Cloud iBox (Air Digital) around €95
pgh13
Midlands UK
Amiko Alien 2 triple tuner may be worth a look? Anyone got one?
