stephenG
- May 15, 2014
- Age
- 44
- Echostar HDS-600RS, Topfield 6000F, 150cm Gibby dish + "twin dish"quad LNB & Gibby feedhorn;
- Grasse, France
The 0800-309 may or may not give you slightly better results than the Gib feedhorn - impossible to say without trying.
But the flange is a non-standard Prodelin with six holes (no thread), so you need an adapter, or get handy (and precise) with an superglue, or even a drill...
I am willing to give it a punt, and so will order a feedhorn.
Getting handy with glue/resin/drill.... no problem, being precise ...hmm.. I can try.
Another couple of questions.
1. If I "adapt" a universal LNB do I need to consider the distance from the probes inside the waveguide of the LNB to the end of the feedhorn or can I cut the LNB at any length ?.
2. Likewise if I make a C120 adapter plate do I need to think about the thickness of this plate ?.
