Few Hotbird channels dont work on my box
yeshu26
Amiko Alien HD box
Self assembled pc:
AMD 3.2 GHZ dual core 64 bit
Gigabyte motherboard
4 GB DDR2
RAID 1 MIRROR 500 GB
Slave Drive: 500 GB IDE
Samsung optical drive
Benq HD 24 inch monitor
Aberdeen
Hello,
With my Amiko Alien box. Following adult channels "Redlight hD, and Hustler HD" do not show at all.
The quality strength on these channels is 0% . Whereas all other hotbird channels are at 100%. Tried manual search but no luck.
What shall I do?
sonnetpete
wordpress.com
Normandy, France
I suppose you've tried a manual search of 11662V, S/R 27,500, FEC 3/4 DVB-S QSPK for scrambled channels? According to KOS that's where they are. Not sure that your particular box has a blind search facility but if so you could try that too.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
1. What is blind search?
2. What else can be wrong? Why these two channels only?
Almost certainly you've got the wrong combination of modulation parameters - these are DVB S, for example, not S2.
Any slight error will result in failure.
.......................... so, one way of eliminating parameter errors is to engage Blind Search: This is a feature which causes all Transponders active at the relevant time to be found by the Receiver, regardless of what manual TP's have been entered and regardless of any pre-stored TP lists.
So, a powerful featire - but it will find lots and lots of garbage (in general) so much weeding out may be required.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
When I do a manual search, and input the channel parameters, the signal drops immediately to 0 %.
Yes. That's the point - check the parameters and double check: We've all done it - thinking we've definitely put all the right parameters in then finding "whoops" we haven't.
11662
V
27500
DVB-S (Not S2)
QPSK
3/4
And just for belt and braces, please tell us exactly and exhaustively what parameters you have actually entered.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
What is belts and braces?
The channels were always there, and stored. But the moment I switch to them it shows "no or bad signal".
Belt and Braces is making 200% sure ..... you still have not specified exactly what parameters you have actually input and the symptoms you state are entirely consistent with one or more incorrect parameters. Precision is vital. Anything less will give the result you've got.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
I am not sure if you experts will believe me, but this really happened.
Out of frustration, I spanked my "diseqc switch", and these two channels started working.
Now please xplain the physics of this please? I am curious that why the switch got "turned on", after "spanking"?
sonnetpete
wordpress.com
Normandy, France
It is possible that, within your diseqc switch you have a poor contact and tapping the switch has allowed the circuit to be completed. Maybe you should look into changing the switch?
I can't leave this reply without commenting on the fact that in order to view two adult channels the solution involved "spanking" resulting in being "turned on".......each to his own.....
Spanking your DiSEqC switch seems akin to tapping the casing of a dodgy Relay to free sticking contacts.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
What intrigued me, is the fact the signal dropped to 0 % in only these two channels. Else I have 5e, 28 e, and hotbird working very well on the same switch.
My Sado switch!
Sometimes it's best not to think to hard about these things and just shrug the shoulders and carry on!
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Sorry Tivu!
Just one small question please, wrt this topic.
I need to lay some satellite cable through my garden (under the soil). This cable will carry Sky signal. Should I use webro cable or the cheaper RG6?
I used Webro cable for 5e(fringe reception of nordic beam), as I could not afford any signal losses. But in the case of Sky, is there a room for slight signal loss?
RG6 should be fine unless the run is well over 30m.
Are you going to run it in a conduit eg some plastic plumbing pipe or similar?
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Conduit, not really.
Are these cables not weatherproof?
Are you going to run it in a conduit eg some plastic plumbing pip or similar?
Yes, but it's often a good idea to provide extra protection - to prevent physical damage due to a badly aimed spade and to provide further resistance against permanent exposure to wet conditions (depends on the type of soil and it's drainage properties to some degree).
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
in what situations wf100 is better than rg6?
