Fibo Gregorian 1.2 conversion to multi lnb
Toyboy
Extreme Hornet + 1.2m dish
Mine's in the garage waiting to be re-united with the rest of its body parts. So.. where is the 'entertaining' stuff these days ? I need to crack on..
Yes I know but rather than having a single lnb with the dish swinging away I'd rather have it fixed with access to 4 Sats. Also, the moving part of the polar mount seized up a while ago, took some leverage to make it rotate again but the nylon sleeves between the fixed & moving parts got trashed so now it's not a snug fit & there's some play and metal-metal contact.
The cog on a Fibo when worn could be replaced with a bronze alternative.
Trust
Nijmegen Netherlands
I repaired it with the material of a RedBull can "
With some new grease worked as new .
Toyboy
These are the rotating parts that grind
None of those parts look like 'nylon'.
Have you tried banana skins ?
Toyboy
Let me spell it out to you. The grinding metal parts are missing nylon sleeves which stop them rubbing together and take up the slack. Banana skins ? Is that what you've been smoking ?
Toyboy
I could try heavy duty grease but it would just seep out
Trust
One mount I repaired with a rollerbearing at topside and a sheet from a beer can .
A second mount with only such sheets at both rims .
For a friend who wanted more arc (75º E) I cut away a part of the mechanical end-stops .
Gerard_Dirks
Fibo 55/90
Switzerland
@Trust1
Hello
I saw your construction. It is exactly what i am looking for. I want to use it with the 55cm Dish. Can you tell me were I can find these parts (Monoblock & LNB Holder)
Regards
Gerard
Did Fibo make a 55cm dish ? If so what motor drive was it fitted with ?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Sure, the company had made famous casted aluminum Fibo55. Very nice dish. It had exactly the same polar-mount as Fibo90 and motor itself was also the same. But, I think that @Gerard_Dirks is only looking for LNB holder.
Trust
@Trust1
Hello
Regards
Gerard
Gerard , those parts are still at my shed in Nijmegen NL , but it was made for a 1.2 m Fibo .
For the 55 cm Fibo the lnb must be more close to the feedarm .
I suppose you are from the netherlands also , so you can send me a PM in Dutch
Unfortunately Gerard has only made one post so won't be able to send PMs just yet.
Trust
OK . Than I will see his reaction overhere or is it possible to start a conversation with him when I am the starter ?
Gerard_Dirks
Fibo 55/90
Switzerland
There is picture of my set of Fibos (55, 90 and 120cm). View attachment 125737
Hello RimaNTSS
I also own the motor for the 90 & 120cm. I can say that the 90cm Motor isn't compatible with the Fibo55
RimaNTSS
N-E from Riga
Maybe you wanted to say that motors from Fibo120 and Fibo 55 not exchangeable? Fibo55 and Fibo90 have exactly the same polar mounts and motors....at least what I have. Could you show some pictures?
Gerard_Dirks
Fibo 55/90
Switzerland
Hello
My question is more stupid, because I don't know the influence of the Reflector in front of the LNB?!?
Their are a lot of Monoblocks on the Market. e.g. with Astra19/HotBird13. Because of the mirror-effect of this reflector will the Monoblock need to be an other setup (e.g. 3 degrees). I think it need to be less distance?!?
I want to use my combination for Astra19.2 & Astra 23,5, so the Monoblock for a normal Dish should be 4.3 degrees (Optimum Monoblock Twin LMTP-43H)
What Monoblock do I need for the 55cm Fibo? 3 degrees, 2 degrees? I have no idea of the multiplier effect of this reflector.
I think if I can't find an OutOfTheBox LNB Holder, I will ask someone to print a 3D Print Holder ?!?
Regards
Gerard
Fibos, by design, are not meant to be used in multi-feed arrangement. It can probably be done but more hassle than it's worth. I suspect performance will also be less than ideal, especially on a such a small dish. 3 degrees of separation will certainly not be achievable - there's not enough room for LNBs on a dish this size.
