Just Sharing This Gibertini 150 rotation Diqec amiko motor 30W-68.5E @Beli1910
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
But here I will post the conversion of the construction of the Diqec motor for rotating large antennas. The antenna is on a balanced arm and the rotor load is zero.
Here is link where you can see sistem.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
If anyone is interested, I can attach a couple of pictures of the rebuilt engine construction. The old Gibertini antenna has been replaced with a new one and the system has been working without problems for a year and a half.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I will find some pictures in the archive
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Is that a Ku LNB (IBU Twin?) with a C-band feed horn?
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Yep.
IBU with skalar ring-give me good result.
Interesting, does the LNB still have it's original feed or did you cut it off? What gains do you see with the scalar on?
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
The Lnb has an original source. By adding a scalar ring, I mostly improved the signal by 1 to 1.5 db. I have measurements somewhere on the forum, or on several of them. I am talking about the gibertini 150 antenna. With this combination, I have much better signals than with the original gibertini feedhorn and flange lnb.And beter result with other lnb.
There talk about ku band signal.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
One interesting test from my friend @LambdaKt.
Interesting - this, to me, sounds like the cone around the LNB stops some ambient noise coming in, rather than funnelling useful signal down the throat. I am probably wrong here.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
When I get some time, I will make a video for you so that you can see the difference in the signal with and without the scalar ring. Of course, with a measuring instrument.
