Guide - How to Record from your Dreambox to your PC Hard Disk using Ngrab
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
If your Dreambox is not equipped with an Hard Disk or DVD burner, and you would like to record your favourite TV programs, here is a guide that explains how to do it using Ngrab.
Please try it and, should you have any questions and/or comments, post them in this thread. I can then update it, till it is idiot-proof :D:D:D
EssBee
Dream DM500
Cbean
Thanks DeepRiver. I will try to follow this.
terrybobs
dream7020/2 x dream 500/d600pvr
europe
working a treat thanks
regards terrybobs
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
What is the difference between ngrab and cifs?
billnot
Growing Old Disgracefully
Famaval 3,1, IP9000HD plus other FTA and Linux boxes - Astra 1&2, Hotbird, Hispasat
Benitachell, Alicante, Spain
I have a 7025, which doesn't have any Expert Menu. I can't find where to set up Ngrab on it.
The PC end of Ngrab is seeing the Dreambox OK.
mhku
TM Nano ~ sg2100
Midlands
I think ngrab is a plugin.
DeepDiver
I would'nt say that ngrab is a plugin, as you actually install it on your PC rather than your DB. It is an application that communicates with your Dreambox, and records on your PC hard disk.
The application can be downloaded here
h**p://www.dbox2.info/download.php?catid=5
Most images offer the possibility to record via Ngrab, CIFS or NFS.
For the guide, I used the Nabilo v0.8 for 7020.
Some images like Gemini include a plugin to start/stop ngrab without using the timers. Other images do not.
For this reason, I have provided the steps to time a recording via webinterface. The webinterface applies to almost all images.
PCD
DB Magician
Has anybody tried this with a 5620 or 500 ?
I found (of course a long time ago) that recording from both ngrab and cifs was very poor with a lot of pixellation on many channels with films and music.
billnot
So how does the ngrab menu appear on the DB, then? This is where I'm confused. I've installed NGrab on the PC, pointed it at the DB IP and it has found the DB - at least that's what my very limited knowledge of German leads me to believe (verbunden mit 172.26.0.xx).
But there is no mention of Ngrab in any of the Gemini menus on the DB. Do I have to install a plugin on the DB, and if so, what and from where?
DeepDiver
The IP address must be edited in the Ngrab. You should not leave the one you find written there. Ngrab does not detect your DB Ip address.
The DB IP address is the same you use to transfer files with DCC for example. It is set in Communication Setup.
It should be in the Blue Paner, else, it is possible that Gemini images for 7025 do not support it yet. It works perfectly on 70x0.
billnot
OK. It's obvious that the Gemini for the 7025 (currently at 2.3.0) doesn't support Ngrab.
As I said. Ngrab can see the DB - I have the correct IP address. It's just that there's nothing in Gemini to make use of it.
All part of life's rich tapestry!
entouch
DM500 | Gemini | Gbox 2.1b
Holanda
I confirm that it's in the Gemini (2.69) - hit yellow button and you will see it together with G-b-o-x center (in case you've *g*b*o*x installed of course).
My mate has a dm7025, will check if he has it or not.
Could anyone confirm that this works with the dm500s? Because atm it doesn't work if I hit the button in my dm500s.........it freezes.
Will try yours btw.
Regards.
entouch
entouch
Holanda
Nice docu DeepDiver.
I think I finally will have that Ngrab be working after all.
Btw, is the svr port 4000 the one it should point to, or can you change that? I've some other prog pointed at that port atm.
Cheers.
entouch
DeepDiver
Cheers.
entouch
The default port is 4000, and that is usually set by default at both ends, PC and DB.
Should you wish to change, again, it must be done at both ends, both PC and DB.
At the PC side, the server listen port is set in the dBox Einstellungen step
At the DB side, the server port is set in the Ngrab Streaming Setup menu.
Hope it helps.
billnot
Regards.
entouch
Now you have me confused. Hitting yellow in the main menu does nothing. The yellow button in the blue panel selects and deselects autocamd.
It's no big deal - I have a PC hard disk share mounted in /etc/fstab - but I like to try out all the alternatives.
DeepDiver
I'll install Gemini on multiboot, and let you know ;):D:)
DeepDiver
Both CIFS and NFS are protocols that allow the DB to share the PC hard disk. In these protocols, the PC hard disk must be also mounted.
Ngrab is a streaming application, which allows to transport streams to the location where the server is installed. In our case, this location is the PC.
Similar applications are Tuxvision or Dreamview
billnot
Thanks to DeepDiver for trying to help me, but since I have recording to PC working using CIFS (about which I know a lot more than specialist Dreambox stuff), I'm going to forget this for the moment.
I was trying it out as an alternative method that didn't require mounting a PC share in the Dreambox /etc/fstab.
DeepDiver
More than welcome ;)
To be honest, I have an hard disk installed in my DB :D, however, I just like playing with all the different solutions and alternatives.
And this is what makes it fun for me :D:D:D
entouch
Holanda
I tried it, and it works partly?
It does tell me it was successful, but when I go look into the folder there is nothing in there: no recordings???
Has this to do with the mounting of your pc-hd? If so, how you do this?
Btw, I should see it recording, but I only saw it 1-2 times, the other times the icon was green all the time.
Cheers.
