Help !!!! Dm7025
TITMF
Truman Ultra 150 & Starsat X550D Ultra on Hotbird
Qatar
Hello Everybody,
I need your precious help.
I'm trying to get T*S on my dream, but nothing works
My Config : Dreambox 7025 + Gemini image + MgCamd 1.25
I try to use the Satan key bundle in the Var/Keys directory, but I receive nothing except Swiss channels (TSR1 & TSR2).
Did somebody has the same config ? Or somebody can explain what to do and how to do ? Another softcam ? Another image ? Another keys ?
Thanks a lot in advance for your help
Titmf
mhku
TM Nano ~ sg2100
Midlands
Which TPS channels? There are only a few still called TPS (on 19.2E, none on 13E), or do you mean C+ or C Cinema?
Keys are the important part and change often; CCcam is always worth a try.
Satan is not always up to date- there are a few other key updaters around e.g. Florikey and hackSat.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
I think he means the TPS package. i.e this lot:-
C+ and C+ cinema and part of that package.
_http://www.lyngsat.com/packages/tps.html
A nonymous
Just install the DBC Satankey installer plugin onto your Dreambox. You can find it in the usual Satan-Sin places :eek:
CCcam works very well with the TPS (Canal+) stuff on 13e and more importantly it also opens up the Multivision stuff on 13e aswell :-righton
I'm sure there is a plugin that is just primarily for TPS keys which will also be found in the same place as the DBC Satankey updater :-worship
Never used it so i couldn't say how effective it actually is.
:-beer
Nano
